Question about Welding Tools
Plasma cutter problem - is cutting on beveled angle.
I am having a problem with my Thermal Dynamics Cutmaster 81 plasma cutter, it is fitted with a SL100 Machine torch and bolted onto a Torchmate CNC table. The cut it makes is beveled in one direction (not like when it cuts holes were the bevel is expected). This bevel is approx 15-18 degrees. I have done everything I can think of and I am at a loss. I have:
  • replaced the consumables (15 times)
  • Checked to make sure the torch is vertical to the job.
  • Checked the air supply for water
  • Checked the air supply for pressure ( I have tried it on 50 psi through to 80 psi and everything in between)
  • I have checked the grounding.
  • I have check the feed rates and adjusted them up and down
  • I have pulled my hair out
  • I have had 30min conversations with tech support in Australia and America ( they don’t know what might be causing the problem) They suggested I get a new Torch.
  • I have bought a new Machine torch lead (SL100) and on its very first cut it did the same thing.
Any advice would be good, I am desperate.
  • brendangilse May 18, 2009
    Update - I have gone back to the beginning and I am pretending that I have not done anything to try and rectify the machine. I am going to take it to bits and pieces and start from scratch with the manuals from Torchmate and see what happens. As I go I will slowy connect in the bits and pieces and run it untill I find a problem and hopfully this will get me moving in the right direction.
    but still any ideas would be greatly appreciated.
  • 4 Answers
Lecovert, cheers but no luck I have done all these things more than a dozen times. After stricpping the machine to bits and reassembling, I then then started testing by removing parts or interchanging if possible. I have found that the arc voltage controller is most likely responsible as the problem. When it is disconected from the system and I trick it into running semi-manually the bevel is reduced to about 3degrees, which may be just an alignment problem with the torch and the cut surface. I will go on to cheching the alighment and try and get a new Arc voltage controller for the Torchmate CNC side of things.
Posted on Jun 29, 2009
    Champion:
  • 225 Answers
Worked on units for several years,my first thought was torch consumables,then torch itself,so here we go.make sure all the consumables are exact for the torch,make sure all parts are brand new,(all parts,that way we can elimenate that part of trouble shooting).check that the ground is tight on the unit and work peice.When you bought the new torch head did you also buy the lead to the head?If not possible that could be the problem.
Posted on Jun 28, 2009
  • Paul C Nov 21, 2011
    I know this thread is a little old but I am experiencing the exact same problem and I also have the cutmaster 81 (bought in 2010) and a torchmate 4X8 CNC table and have not been able to figure out why it is cutting a beveled angle but it is very frustrating. I also am using the SL100 machine torch, and I borrowed one from a friend with the exact same issue. I thought that maybe there was an obstruction in the torch that may be pushing the air to one side. Not the case, but I am at a loss and no one seems to have any good ideas. Curious if you found the arc voltage controller was the issue? Any info would be a great help!
What causes bevel
Dirty tip, excessive air pressure, and holding tip at an angle- was it ever dropped? If so, it may have deformed or partly disloged something in the cutting head.
Jun 07, 2012 | Welding Tools
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
Cutmaster 81 plasma cutter when turned on, starts normal but air solenoid keeps going on and off. What could be the problem?
Hi:
Sound like you have a faulty start cartridge, probably you used the torch handle to bang a metal part to make it fall. This is a common problem when using the gun as a hammer. Just replace the start cartridge. Before changing it; check the cartridge's lower end, this must move freely up and down.. If you did replace the cartridge already then probably your output power pc board it's damaged.
Regards,
Jun 23, 2011 | Miller Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
Plasma cutter started cutting at an angle even when held perfectly perpendicular. New consumables were put on, same amperage, same air pressure. I'm stumped!
did you put all new consumables in ,sounds like there is still old one there.make sure nozzel is put back together right.I have worked on welders and plasmas for years,the torch head is very tempermental.
Mar 01, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Welding Tools Logo
493 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
