Question about Dishwashers
The door for the soap has a small crack/hole
The door for the tablet has a small crack/hole in it and it wont disolve the tablet (dishlex globle 300)
  • bsimmons18 May 16, 2009
    looking for somewere i can get spare parts for my dishwasher
  • 10,865 Answers
You can patch the crack/hole with a one minute marine epoxy. It works great. Regarding the fact that the tablet won't dissolve, you may wish to try a different dishwasher tablet or powder. You may also have another problem with your machine. Are your dishes coming out clean?
Posted on May 16, 2009
  • Joe Hogan May 16, 2009
    You can get spare parts from each of the manufacturers. For example, if you have a Kenmore or any other dishwasher sold at sears just go to sears.com for parts
I have a Dishlex Global 300 and sometimes the detergent was not empying out when i did a wash cycle (seems that the top rack would prevent the door of the detergent holder to open fully) I just purchased...
it could be your water preasure or the water is hard,,,but like with most dish washers the tablets dont desolve all the way,,,you need more of a liquid soap type of a cleaner
Feb 19, 2011 | Dishwashers
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
My Maytag neptune washer has a bad odor that seems to be transfering to the clothes. What can cause this and how do I correct it.
on the front load machines there is a large rubber door boot which gets built up with soap scum. always leave the door open a little bit when the wash day is done. there is a product available called "Afresh". it comes in a pkg with 3 tablets. if the odor is strong follow the directions and use all three tablets. then for maintenance use one tablet a month in an empty machine. what also helps is to make sure you do at least one hot water only wash per month, this helps to disolve all the soap that gets built up in the dispenser tubes and drain hoses etc. hope this helps.
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soap dispenser drops soap out and tablet does not disolve.
use liquid soap ...those tablets are less messy but they don't work very well ....and make sure to use a dry agent like "jet dry"
Jul 25, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Electrolux Dishwashers
What detergent is best to use in a dishlex global 300 dishwasher? i just inherited one second hand and have to buy detergent. can i use tablets?
Greetings to you your best way to buy dishwasher detergent is jell form it disolves and generatews even cleaning and better to have spot free dishes if you have hardwater put in a squeez of lemon juice in the tray for jet dry it works xcellent
May 31, 2008 | Dishwashers
Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Soap tablet not disolving
Its has been my experience that those soap block dont do a very good job. Try using a gel type detergent for wahing your dishes
Nov 08, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
