Question about Nokia 1600 Cellular Phone
1600 auto on
My 1600 phone water damage.after phone service(pcb clean) then put the batery auto on.......pls help.
    Scholar:
  • 129 Answers
Maybe circuit shot, try to re-cleaning.
Posted on Aug 04, 2010
In Nokia 1600 type RH-64 i forgot security code and now cannot reset call timers, would you pls help?
Good Morning:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 08, 2012 | Nokia 1600 Cellular Phone
I want Nokia 1600 Cellular Phone Water damage logged
If your cell phone is damaged by water follow these instruction
1. Remove The Battery Immediately
2.clean your battery with a towel or paper and let it dry
3.Use air to force out the water from your mobile phone
4.else you can put your phone in a bag or dry rice over night so that in morning the water will be absorbed by the rice from the cell phone
5.now put the battery in the cell phone and try to switch it on
6.There are chances that the mobile get turned on.sometimes if the circuit is entirely damaged its impossible to recover..
I hope this will help you.if this helps you rate this answer
thanks and regards
Lalith
Mar 14, 2011 | Nokia Cell Phones
Nokia 6300 Cellular Phone Problem hai my 6300 hanset under water aftel hanset is on but display light not coming pla help mee pls
Please take out the battery immediately and keep aside do not put back the batery until wee have done a full drying of the set.
Open the set and use a good hair dryer to carrefully dry the board without damaging the display. do not over heat but just warming to dispere the moisture. Repeat process and keep aside for some time. Use a soldering iron to heat or touch up soldering to dispere trapped moisture.
Only after fe hourrs must you try to put back the battery or you will end you damaging the output stage.
so do this immediately
hope i could help. Good day
Aug 17, 2010 | Nokia 6300 Cell Phone
1600 display light problem
Dear Friend, I hope this will help you.. Your Light problem may be Caused Due to Water Damage(NO LIGHT).Then you have to Clear your Hardware Area.
  • Clean Light IC
  • Then Check phone
  • Still Problem Exist
  • Change Light IC
You can Repair Click here (NB:Changing Light IC is Better to do by a Professional. Improper handling may lead to total Damage. )
IF THIS HELPED YOU in any way DO RATE ME...
Thanks For Using FixYa
Apr 17, 2010 | Nokia 1600 Cellular Phone
Nokia keypad is not working
good day ! the problem of your phone is keypad main brain try to clean that or chagne the mainbrain ! good luck ! thanks ! ....
Sep 09, 2008 | Nokia 1600 Cellular Phone
Pls help me out
Is this phone water damaged? If other functions are ok then your lcd may be displaced. If you have a proper screw driver you can open your phone, clean the connector and put the lcd correctly and assemble your phone, it will work again.
May 20, 2008 | Nokia 6288 Cellular Phone
Nokia 1600 backlight switched off cant see a thing!! :( help!!
just pull out the batery without turn it off that will reset the original configuration
Dec 27, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
