Question about Honda Garden
Having carburetor problem with honda f210 tiller and it won't stay started
    President:
  • 1,902 Answers
I need the year make and model. This sounds like you just need to adjust the idle screw or clean the carb with some carb cleaner and it should be good to go
Posted on May 16, 2009
Tiller won't start
well I would be checking the gas first...
Dec 01, 2013 | Garden
Rototiller won't start
A small engine carburetor sitting with gas in it is a a problem waiting to happen the ethanol in fuel clogs carburetors and it sounds like it has done it to yours remove and clean carburetor with carb cleaner that may do the trick or you may have to soak it in cleaner solution and rebuild if the rebuild does not do the trick you may need a new carb as some of the jets are clogged Try to run engine completely out of fuel leaving the carburetor empty s to help with this problem in the future also using a fuel additive for ethanol is helpful
Oct 22, 2012 | Garden
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Need new carburetor
I will check to see if I can get you one at a resonable price.
May 07, 2009 | Garden
Honda f210 tiller leaks gas when not running. if you leave the gas valve on it leaks on the floor. if you start it you have to regulate the amount of gas going into it, or it will flood out. it runs rough...
yes that's the problem.float level...you remove the float bowl and bend the float until it is at the factory specs.get you a manual and it will tell you the float height.if it says 4/32 you get you a 4/32 drill bit.put *** under the float chamber and bend until the bottom of the float touches the bit.
Apr 29, 2009 | Garden
Garden Logo
1,087 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
