Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have two remote controls I can get one or the other to work not both at the same time
  • 10,865 Answers
Check and see if one remote has a green light and the other has a red light. Not all remotes are compatible and interchangeable with craftsman products.
Posted on May 16, 2009
Haier LCD remote control HTR-D18A
I have haier remote htr-d18a its 2nd time stoped and this time i try most of time for syncronise but its not work. Plz tell me what i do. For sms 03328886166
Jun 29, 2013 | Televison & Video
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
TV LIGHT BLINKING. REMOTE WILL NOT WORK
Got a short in the remote if light blinking on IT all the time---got dropped or something spilled on it?
Oct 29, 2012 | Samsung BN59-00598A Remote Control
Ceiling fan stoped working when pushed two butons of the remote control at the same time
The fan's main system control might have entered into it service mode. Contact the delaer from which the fan was bought.
May 01, 2012 | Casablanca Fan W-52 Remote Control
The power went out and my RCA tv needs to have the time set to continue watching. But the remote does not work, and I can't access the menu from the tv
Hello
If the remote control doesn't work, just buy one RCA RCR model universal remote control. Without remote control, you can't set the time to this set.
Mar 04, 2012 | RCA Televison & Video
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
I programmed a phillips tv with the dish remote control and now it does not work with the dish receiver. help!
Hello, Matt with DISH Network here. Make sure the remote is in satellite mode by pressing the "SAT" button one time in the top left of the remote. If the remote is still not working, open the door on the front of the receiver and press the "System Info" button one time. When system info is on your screen, on the remote press the "SAT" button one time, and then press the "record" button three times. Try pressing select on your remote an it ideally should be working. Hope this helps.
Dec 26, 2010 | DISH Network IR Remote Control
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Remote stops working does not respond all the time
change the battery that should be the problem if the problem still persists then its hardware problem got to get a new remote.
Jul 14, 2009 | Samsung TV Remote Control
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
56 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
