Question about Sony VAIO PCG-R505 12.1 in. Flat Panel LCD Monitor
LCD turns white.
After a while, the lcd on my sony vaio pcg r505el turns white. If i hit fcn-f7 a few times sometimes it will come back for a few mins then go back to white. is this an inverter problem? Help!
    Sergeant:
    Champion:
  • 225 Answers
Probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. best regards
Posted on May 17, 2009
How can i reboot my sony laptop tpye pcg-r505el
open command prompt and type shutdown then hit space button then -r then hit enter button your laptop will reboot
Feb 19, 2011 | Sony VAIO R505EL Notebook
Hi there i have the sony pcg-3H and i cant get it to sync to the LCD, i have pressed control F7 and tried the various options and still nothing the cable works with all other laptops
Hi Lee1311
Regarding the issue that you are having with the computer will not sync with the lcd monitor you may need to check the video settings and video card settings or video control panel
You could also try to use a different VGA cable for the issue
Hope this helps you with the problem
Thank you for choosing fixya
Jan 27, 2011 | Sony VAIO PCG-K35 Notebook
I have a sony viao pcg-k23, when i open and power it on it has white displayed on screen white horizontal lines. what must be the problem? thanks
This is most likely an LCD screen fault. You could check the LVDS cable that connects the motherboard to the screen also.
Jan 21, 2011 | Sony VAIO PCG-K23 Notebook
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
After i've read the solutions from some experts, I did what they advised, I "rebooted" ,"deleted some unwanted files and recent programs" I installed in it, tried "msconfig", "run", "CHKDSK " and "cleaned...
Given all the steps you've tried thus far, it may just save you time and frustration to just wipe the machine and start over. Given you can get into safe mode you might be able to copy any of your important files off to a usb thumb drive or usb hard disk before you wipe it.
If the laptop still has problems on a fresh install of windows, then its time to call in warranty repair.
Nov 21, 2009 | Sony VAIO PCG-GRT360ZG Notebook
Sony vaio pcg-r505el won't turn on
Vista or xp? I'm assuming Vista?
Apr 06, 2009 | Sony VAIO R505EL Notebook
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
MY VAIO SCREEN TURNED WHITE
What type of vaio is this?
First attach an external monitor or go to your friends home ,they may have an old crt monitor or lcd,just remove the video cable from their system and plug it into your laptop video port.
when powering-on laptop -press the FN key and the F7 key at the same time to toggle the video signal - video will show on the external monitor or if not you have to replace your LCD.
The above test will verify if the LCD is bad or you have an inverter problem.
Jan 08, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony vaio pcg-fx120
so it shows up externally only?? if so did you try replacing the inverter.
Oct 31, 2007 | Sony VAIO FX120 Notebook
Sony VAIO PCG-R505 12.1 in. Flat Panel LCD Monitor Logo
263 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
