Question about Acer AL1711 17" Flat Panel LCD Monitor
A/C adapter is getting very hot
After short use time hot adapter
    Problem Solver:
  • 7 Answers
Ma by you need a new adapter
Posted on May 16, 2009
My chevy impala keeps running hot eventhough the radiator and the fluid isn't getting hot. But after running for a short period of time or trying to drive for a short period the car runs hot and c
I would start by checking the fluid to make sure it's at the proper level, Then check to see if the thermostat is opening like it should. If you have good flow and you get heat inside the car but the car still overheats I think I'd be checking for blown head gaskets and head warp.
Jan 30, 2013 | Cars & Trucks
WHY IS THE BATTERY LIGHT FLASHING ORANGE,AND THE BATTERY IS GETTING VERY HOT.
Some adapters do get very hot after a long time of use. flashing light alot of the time indicates that it is no longer charging. Might be time to replace adapter
Aug 12, 2012 | MSI Computers & Internet
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
Apr 11, 2012 | John Deere Garden
My mini netbook will not charge, had it plugged in and the plug was extremely hot and now it will not charge
The battery may be shorted or the charging circuit on the mother board has a short causing the power adapter to overload. If the adapter is still functional remove the main battery and monitor the temperature of the power supply, if normal the battery is the culprit.
Feb 05, 2011 | Computers & Internet
MY PRINTER WILL NOT TURN ON OR OFF. NOT ABLE TO PRINT ANYTHING AS IT IS NOT CONNECTED ACCORDING TO THE PROMPT ON MY COMPUTER. HOWEVER ALL THE CONNECTIONS ARE IN PLACE. THE AC ADAPTOR IS HUMMING. I...
It is possible that the printer has a short in the main board. SO first of all remove the adapter and see it this heats up without connecting to the printer, check the voltage of the adapter.
If Ok then open printer and check the input power line .Use a multimeter to check for short, if not been able to check a short connect adapter and see if any component is heating.if so the component /IC is confimed to be short.
Only if the printer powers up do we need to install software, connecct printer to be detected to complete installation.
Confirm/credit me if you get this right.
Aug 26, 2010 | Dell A940 All-In-One InkJet Printer
Compaq V2000 overheats at power-in plug.
Sounds like the power jack has a short and needs to be replaced.If it melted the ac adapter tip then its a ground problem in the power jack or where it connects to the mother board.
Aug 11, 2009 | Compaq Presario Notebook
I have Gateway MX6027 laptop. My ac adapter get real hot. i went through 2 chargers in the last 2 months. I am wondering if I got a short on the motherboard, or maybe if there is a voltage regulator that...
Does the AC adapter get hot if you use it to power the notebook with the main battery removed? If not, the battery or internal charging board may be faulty/
Mar 03, 2009 | Gateway MX6027 PC Notebook
Inspiron 4000 power problems
When power supplies go out, they can cause some real damage to the machine, especially in this case, it being hot indicates a short. First let's talk about the new adapter, if it's a Dell replacement great, if it's a Targus universal not good. The Targus supplies don't work well with Dell machines and can cause problems, return it and get a Dell replacement. If you have a Dell replacement, then try removing the battery and powering it up just with the adapter. Sometimes the adapter going out can cause the battery to develop a short, and this will cause the machine not to start. If the problem still exists at this point, you will need to take it in for a diagnostic, because the problem will be somewhere inside, most likely the motherboard.
Jul 12, 2008 | Dell Inspiron 4000 Notebook
Acer AL1711 17" Flat Panel LCD Monitor Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
