My printer not given print when i give one paper print one page blank copy come out first and after that next page start printing but that after next page half paper jammed in printer so i very bad thinking for canon company printer .My all printing work pending so am a very serious problem please solve my problem Regards, Rajkumar.Alwar(Raj.)
SOURCE: PRINTING PROBLEM WITH CANON IP1880
please try
http://canon-resetter.blogspot.com
http://epsonresetter.blogspot.com
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
SOURCE: False paper jam warning on Canon Pixma iP3000 printer
I have been using the Canon MP180 PIXMA for almost three years now without a hitch until I received a paper jam warning which I could not resolve. I Googled "Canon PIXMA paper jam" today and landed on this site. I turned the printer upside-down and shook vigorously. Out popped a small pebble-like bit of concrete which somehow found it's way into my printer. I guess our hardwood floor installation on the floor above had shaken up some old plaster and concrete bits that had lodged in our drop-down ceiling from our 3rd floor bathroom renovation last year and this little ****** came through an opening in our rec-room (where the computer and printer are) drop-down ceiling. A very strange sequence of events, that I would not have suspected, but happy to say that your advice here did the trick and the printer is a tough and trustworthy little printer afterall! Thank you. Dan in Canada
SOURCE: my printer is pixma canon mx308.when printing,the
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
