Question about Spectralink (PTB400)
As soon I turn on it shows internal error 8 & 4444-444c
Http://depts.washington.edu/uwmcdir/spectralink.html Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
  1. Power off the phone.
  2. Press and HOLD the volume key (VOL) and the power key at the same time (the phone will chirp and display the serial number.)
  3. Now…release ONLY the power key (phone will vibrate and make a long tone.)
  4. Now release the volume key (the display will have a lot of black boxes and ZZZZ’s – you will also see the bottom of the display showing “msg”, “bat”, etc.)
  5. Count to three and then power off the phone.
This “soft test” is to correct only certain internal error messages. When the phone is experiencing a correctable error the display will read “internal error 8” or “internal error 4444-444C”. For all other internal errors the phone will need to be taken to Teleservices, NE-165 to be replaced.
Posted on Mar 24, 2010
Brain lara cricket supoorts windows 8
Brain lara international cricket 2007 doesnot support windows 8 and windows 8.1 platform so it gives some errors like 0x00000xxx. Downgrade the operating system to windows 7,xp or windows server 2008 then it works fine. It is not the pirated cds problem its platform problem. You cant even run in compatible mode in windows 8,8.1.
Dec 24, 2012 | Codemasters Brian Lara International...
Toshiba estudio 181 when i power on the machine and press cleare & stop key its show error c 44
that is mean that you have a problem with the fussier , first open your machin with press 0+8 then press 400 start entarrabt if that don't help you so If you can check the fussar
Oct 05, 2012 | Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Error 6 & 8
Error 6 is a scanner failure I believe and no 8 is an software installation error http://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Error-8-8-0-0/td-p/202248 please have a look at the post on the bottom of this page.
Mar 17, 2012 | HP LaserJet 3055 All-In-One Printer
Spectralink PTB400 internal error
As per : http://depts.washington.edu/uwmcdir/spectralink.html
Mar 16, 2010 | Spectralink (PTB400)
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
Blue srren fatal error
you was probably installing updates in the background and youve interrupted install and shutdown improperly (reason)
turn on pc and press f 8. if youve never done this before;as soon as you see anything at startup keep pressing f 8 youll still get to the place you want to be.select start up using last known good configuration.
Mar 02, 2008 | HP Pavilion dv6000z Notebook
Spectralink (PTB400) Logo
1,147 people viewed this question
Top Spectralink Computers & Internet Experts
David Payne
David Payne
Are you a Spectralink Computer and Internet Expert? Answer questions, earn points and help others
