Question about Cub Cadet Street Sign- tractor lawn riding mower parts
No spark I put new spark plug and gaped new
No spark I put new spark plug and gaped new magneto and gaped new regulater new relay new battery new safty switches fuse isgood still no spark thanks
  • 25 Answers
Check the small wire coming out the magneto maybe it is grounding out somewhere, disconnect it from trhe magneto and then see if you have spark
Posted on May 17, 2009
My john Deere turns over but want start
If it's a single cylinder engine, my first guess is the magneto is defective. Other possibilities are defective spark plug or spark plug wire (from magneto to plug). Verify also that the fuse is good.
Jun 17, 2015 | John Deere Garden
What would cause a no spark situation on my honda rancher 350?
Check...
Battery
Points
Coil
Magneto
Ignition switch
Kill switch
Neutral safety switch
Aug 10, 2014 | FMF ATV HONDA RANCHER 350 2000-2006...
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Im not getting any power to the fuel pump
In the fuse box is a fuel pump relay, most relays are the same switch them around.
Aug 22, 2012 | 1987 Toyota Supra
I goof! i hook battery up back wards now i have no spark
check the fuses then check the safety switches by pass them with a paper clip to test the switch
Apr 22, 2012 | Garden
Is there a hot wire that goes to the armature on a 18.5 2 cly b&s engine
did you replace the armature or the magneto?the magneto has the plug wires on it the armature charges the battery if you put on a new magneto annd you have no spark check the safety switches
Apr 12, 2012 | Garden
Chain saw died, no spark. replaced the magneto, still have no spark. gaped it with a .010 brass feeler gauge. disconnected the grounding wires. could it be possible to have 2 bad magnetos. Repalcement part...
Hi, gap should be 8 thou. Try this with a new plug. Check the magnets on the flywheel. It is possible to have a faulty new magneto but not that likely. Also check that the sparkplug terminal is contacting through the high tension lead correctly. Regards Phil.
May 16, 2011 | Ryobi Factory Reconditioned 18" 40cc...
John Deere GT263 wont start. Wont even fire, turns over OK
DO you have spark?? To check for spark pull spark plug out. With the spark plug connected lay the spark plug on the block of the engine( something metal) and try to start the engine.waych for aspark as the engie is turning over. Does it spark?? If not check the safty switches - Break petal, seat,blade engagemment switch. Also check the coil/magneto.(without the right tester for goil ) you will have to replace the goil. A little pricey. If you have spsrk, the problem is in the fuel system. Is there gas in the tank? Does the tractor have a fuel shut off in the gass line? Is it open?
Close the fuel shut off valve or crimp the fuel line with vice grips or some type of locking plyers. Remove the carborator bowel. Is there gas in it? Yes, Carborator needs cleaning. No, open the fuel line and see if fuel flows out of line. If not check and see if obstruction on line or tank.
Most importantly is the spark/ ignition system. mainly the safty switches and the coil/magneto. If any ofthe safties are open you will not get ANY spark. If the switches are working correctly I suspect it will be the the coil.
May 03, 2011 | John Deere Garden
Brand new Baja 90 ATV - has no spark
I have a new baja 90 atv. it has no spark. Cranks over fine. fuel fine, tried new plug cked all wires fuse fuse ok. what do you suggest.
Jun 05, 2009 | 2005 Qianjiang QJ150
My 1996 cavalier Z24 wont start
pull a wire and ground it via useing a screw driver at the end of the spark plug boot to check for spark / if their is no spark / ignition control module / there is also a crank shaft position sensor / located on the back side of the motor under the coil packs / pain to get to / also the nuetral safty switch / to check the neutral safty switch diconnect the big harnest at the neutral safty switch put a fuse tester to the yellow wire / have someone turn the key / with the tester grounded the light should come on / now we know the ignition switch has power going through it. if there is a no power at the yellow wire / bad ignition switch / does the car have a relay located at the top of the radiator core support (up by the radiator looking down drivers side)if it does not gm will install one for free / if there is / look for the purple wire coming out of the relay and Follow it down to the starter / reconnect the neutral safty swtch / touch the small S (the smallest screw) terminal on the starter soilenoid / have someone turn the key forward check the light / this will detemine if the relay is good / CAREFULL NOT to touch the big starter wire with the little one it will jump the starter / I HAVE THE SAME CAR / Hope this helps
Oct 16, 2008 | 1996 Chevrolet Cavalier
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
559 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
