you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Comments:
Oct 24, 2007
- The only thing left here is to look where the counter would be mounted and see if a connecter has been unpluged or a wire has been cut.
projector comes on for about a couple of minutes then it shuts itself off. Where can I go to have...
(More)
projector comes on for about a couple of minutes then it shuts itself off. Where can I go to have it looked at? I live in Arlington, Texas.
i just hooked up HP 2610 and I cannot print pictures and it does not pint from computer that is to...
(More)
i just hooked up HP 2610 and I cannot print pictures and it does not pint from computer that is to say print is miniscule and not all of text. It also says I need paper
It will work fine for awhile, week at a time and then it will not work at all. When was production...
(More)
It will work fine for awhile, week at a time and then it will not work at all. When was production date; i am being told that parts are not available, is that correct?
