Question about Samsung (SP1614C) 160 GB Hard Drive
Spins up.Spins down.CLICK.Spins up.Spins Down
I have a maxtor 200 gig (MAIN) and a samsung 160 (backup)... Ill be on my computer and then sometimes it freezes and you can hear one of the hard drives (not sure wich one) slows down and then speeds back up (does this about 10 tens) and then its fine (for about an hour)
  • 585 Answers
Check the settings for power saving. Perhaps the system is trying unsuccessfully to shut the backup drive down. Putting the backup drive to sleep when it's not being addressed is actually a good idea and extends the life of the drive tremendously, it is afterall for backup so you want it to last. For example, I have a second drive in this Linux box, It comes to life only when accessed.
Posted on May 16, 2009
Does my Maxtor back up my iphotos?
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
Feb 12, 2014 | Apple MacBook Pro Laptop Computer with...
Seagate spins up clicks spins down
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Aug 20, 2012 | Computers & Internet
Whate does code 10 error mean my maxtor is not opening I even have a new adaptor
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope it helps you
Mar 05, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
My desk top crashed and I have all my files backed up on a Maxtor 3200. How do I down load my backup files from my Maxtor 3200 to my new lap top. I can't find any paper work for it.
Just plug into your laptop and find the drive for it, then enter into the files that you want to put on your laptop.
Copy and paste these files into your laptop hard drive, don't cut and paste just copy and paste them.
That way you will always have them incase your laptop should go down.
Hope this helped.
Thanks
Jason
Oct 19, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My computer no longer recognizes the Maxtor one
Windows may be recognizing the drive but not assigning a drive letter for some reason. you may need to go to disk management2_bing.gif and look for the drive there.
to do so go to control panel/administrative tools/computer management
once computer management is up find disk management, inside you will find all the drives that are connected to your computer, you should find your drive, If you do not then the drive may be bad or you are having usb issues.
If the drive is there but does not have a drive letter assigned to it, this may be because another drive has taken the letter normally assigned to it, you will need to right click on it and say "assign drive letter"
Let me know if this helps.
Mar 17, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Maxtor 3200
Try connecting the Maxtor to another computer and if it functions normally, then backup your data. Then try formating the Maxtor on your computer.
Sep 08, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Seagate Barracuda 7200.10 250mb HDD - Spins up then spins down
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware/
Dec 25, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
MAxtor hard drive wont connect
is the hard drive detected by the BIOS?
you can verify if your hard drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition and format it again from here and it will appear in your my computer.
Dec 15, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Samsung (SP1614C) 160 GB Hard Drive Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
