Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0pt 5.4pt 0pt 5.4pt;
mso-para-margin:0pt;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I will try to make this as clear as possible, but if you have any questions,
please
come back here and let me know.
You will need 3 things: Modem, Wrt54G,
computer. Put them next to each other without having plugged in
anything (no Ethernet, no power cable!). Make sure that the WRT54G router is
back to default settings by pressing the reset button on the back of the router
for 10 seconds while it is powered on.
- Connect the power cable to
the Modem. Power light on?
the router and wait until the power light is on steady.
- Connect your modem to the
router. Plug an Ethernet cable first into the modem and THEN into the WAN
port (the label says "Internet") of the router.
- Plug an Ethernet cable into
one of the router LAN ports and connect it to your computer.
- Power on the computer.
- Open the Control panel and
the Network Connections applet.
- You should see something
called "Local Area Connection".
- Double-click on it and
click the Properties button.
- Double-click on
"Internet Protocol (TCP/IP)" and make sure both radio buttons
are set to "Obtain...automatically".
- Close all Windows by
clicking "OK".(The second one takes a moment, because it applies
the settings.)
- In the open window choose
the Support tab and you should see your IP address, your Default Gateway
(192.168.1.1) and your DHCP server (192.168.1.1)
- Open Internet Explorer and
type "192.168.1.1" in the address bar.
- If you had reset your
router to factory defaults, leave the username blank and type
"admin" in the password field.
- On the first page (Setup),
you should set the Internet Connection Type to "DHCP" (if you have a cable connection), unless
you get a static IP from comcast (which I doubt). Here you might have to choose PPPoE, if you are using DSL.
- Go to the Wireless tab and
ensure that wireless is enabled.
- Go to the "Security
Tab - Wireless Security" and ensure that NO security is enabled for
now.
- Open a new browser window
and see if you can open a web page. Use an address that is unlikely to be
in cache - try "http://www.mit.edu" or so.
- Close your browser for now
and come back here later to setup your wireless security etc.
- If you were successful -
sit back for a moment, enjoy the triumph and treat yourself with a nice
drink!
There are a couple of things you still have to do, but the
main thing is done.
- Make sure that you can
access the internet from your wireless laptop before you start changing
settings.
- Get a manual for the router
here.
- Go back to your router's
web page and set up wireless security (don't use WEP
- that is not secure enough)
- Once you're up and running
and feel familiar with the settings for your router, I would change to a
different firmware, because I never was really
satisfied with the Linksys firmware. I use tomato, for the simple reason
that I was afraid of other more complicated firmware and you can always go
back to Linksys, of you don't like it.
So...my fingers are bleeding now, but I hope this helped you
out.
If so, please come back and let me know. Others might have a similar question.
If not, just tell me where you got stuck and we will go from there. According
to the movie 'Galaxy Quest':
"Never give up, never surrender!"
