Does the CDJ 500II need to be played through a mixer or a amp or is it a stand alone CD Player
SOURCE: turning loud on in pioneer deh-p505 cd player attached with kds-p505 cassette player
Normally by pressing the button which give you the menu for balance etc also loudness comes by and you will be able to swicth it on or off.
SOURCE: RCA ports on back of a Pioneer cd player
Well you should have two sets, front and rear. Either of those sets can be used to go to the amp and it should work fine bridged. If your problem still exists then either you are getting a bad signal form the RCA outputs on the deck or have anouther problem somewhere in the system like in the amp or amp connections. What exactly does the amp do?
SOURCE: My Pioneer DEH-P835R Cd Player will play my cd but wont eject
Check in the front and you should see a small hole thats about the same diameter as a paper clip. Open up a paperclip to a straight 2 inches and poke it through the hole. It should release the door so you can get it open or at least seat the cd if thats whats making it not open.
SOURCE: need color code or wiring info for amp remote
The remote wire is always blue with a white stripe coming out of the head unit.
