I have a Sony STR DE 845 receiver with the speaker selector knob (A+B, off, A, B) on the far right side. Recently that switch has shorted out and it has no sound regardless of where the switch is positioned. If you turn the switch very hard to the left (A+B selection) sound will come on as long as you hold the switch, upon release it turns off again.
The unit comes out of protect mode just fine, it appears to simply be a short in the switch. I have removed the front panel and there is approx. 12 points on the circuit. Is there any way to by-pass the switch to operate in a 2 channel mode only?
The buttons on the right side of the unit (tuning, FM/AM selector and mode, muting, equalizer and...
(More)
The buttons on the right side of the unit (tuning, FM/AM selector and mode, muting, equalizer and bass boost do not work. I can make some changes using the remote. For example, I can change stations with the remote. However, the unit's buttons do not work. I tried unplugging it. Sometimes the muting button will work for a few seconds, but this is only a partial solution and is not permanent
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to...
(More)
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to factory specs per the Sony manual instructions... to no avail. I do not have anything connected to the surround inputs. Although I have the Sat/TV, DVD and Video 1 inputs connected. Prior to moving, I discovered the right rear channel not functioning (I noticed the right rear speaker problem after a Direct TV installation tech switched out my Direct TVR. I assumed that it was a loose wire) now it seems neither of the two rear channels are working.I disconnected and reconnected the speaker wires. I ran the onboard "tone" check and the three front speakers function and supply the 'white noise' indication. The rears are silent when the display indicated that they were being tested. Are the rear speakers fuse protected? Anyone with an idea of what might be going on??
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from...
(More)
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from relay 2)Display intermitantly works
