Question about Refrigerators
My Hotpoint Refirgerator has a freezer temp of 15 degrees F and the box has a temp of 38 degrees F. Both setting are set on high. It has always been this way. What can I do to make both freezer and the box colder.
  • John Tripp
    John Tripp May 11, 2010
    Look on your refrigerator and get me the model number as listed in place in the photo below. I'm not sure which refrigerator you have so if I guess I may be wrong. Does your refrigerator have two settings that are recommended to start at position 5 for freezer and 5 for fresh food. It also could have a damper stuck open so I will need that number to direct you in the right direction. Your freezer should be around -5 degrees F and fresh food 38 to 42 is OK providing there is no freezing in lower areas like the vegetable drawers. Let me know and I will help you solve this,Thanks, Sea Breeze appliancepartsse@yahoo.com
    http://servicepartstec.blogspot.com/
    Master:
  • 492 Answers
Make sure the coils are real clean and not clogged with dust and stuff. Also make sure the space between the wall and the frig is at least 3" so as to make sure the back of the coils has plenty of ventalation. This will provide maximum efficiency at high settings.
Posted on May 16, 2009
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
How to set refrig temp settings
The normal factory settings are usually directly in the middle for machines that have dials and for electronic controls the freezer should be 5 degrees F of below and the fresh food side should be between 34-38 F.
Jun 17, 2012 | Hotpoint HTS16HBR Top Freezer Refrigerator
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Evaporator unit keeps on building ice. question what is the nornal operating pressure on low side and on the high side for truee freezer using 404 refrigerant
I'll try to give you the "Readers Digest" version.
First, make sure there is no ice build up on the evap. Light frost is O.K. as long as it does not effect air flow. (Very Important). All fans need to be running. Again, an air flow thing. There should be some product in the box but not too close to the evap. Again, an air flow thing.
The expansion device can effect your pressures to some degree i.e. Cap tube vs. TXV.
As a general rule of thumb, which I use almost everyday when it comes to pressures:
Low side is based on the temp difference between evap temp and condition space in the box. In freezers, it is almost always 10 degrees. If the box is 0 degrees then the evap needs to be at a minus 10 degrees. That is a pressure for R-404A of 24.5 psi. This only holds true when the temp in the box is approching set temp. I would say, about +10 degrees. 0 Degrees for the evap for R-404A is 33.5 psi.
High side should be ambient temp +30 degrees and then convert to a pressure for the refrigerant.
Example: 75 degrees in the room, +30 degrees equals 105 degrees. Now 105 degrees converted to a R-404A pressure is 253 psi. This will get you very close to the desired high side pressure.
I would look at low side first to see if it is within reason. Don't let the high side get too high. Increases the compression ratio and overworks the compressor.
Your icing problem could be a defrost issue and not a refrigerant charge issue.
Good Luck and hope this gets you started.
Apr 07, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Whirlpool ER8AHMXRQ01 fridge too cold
Adjust the setting until you can maintain a temp of 0 in the freezer and between 32 and 38 in the ref. These are the normal operating temps for this box.
Apr 02, 2009 | Whirlpool Refrigerators
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
