Question about Weather King 10AJA6001AH Air Conditioner
How to put freon in?
Where do you put freon in this system
    President:
  • 2,559 Answers
Warning: It's a federal crime for anyone not EPA certified to charge a unit.
With that being said,The charging ports are located on the outside unit,You will need the proper set of gauges,an outside ambient air thermometer,a jug of refrigerant,an adjustable wrench,and the proper size allen wrench.
You will need to attach one end of the yellow(center) hose to the tank(leave the valve on the tank closed for now) and leave the other on the gauge manifold,Attach one end of the blue hose (left)to the suction line(the big one) and leave the other attach to the gauge manifold,Attach one end of the red hose(right) to the high pressure line(The small one)and leave the other attach to the gauge manifold.You will then need to take the temperature around the unit(ambient temperature)once this is done,you are ready to charge the unit.
You will need to remove the brass cap on the charging port,Insert allen wrench and slowly open the valve,the pressure on the gauges will rise to the current pressure,You will now need to start the unit and let it run for about 5 minutes or so,until the pressure stabilizes on the gauges.With the temperature from earlier you can begin charging the unit,but without me knowing what the temp is I can't tell you what pressure to charge it to,So the remaining steps cannot be completed.
Posted on May 16, 2009
97 Plymouth Breeze won't blow cold air due to freon leak.
Your AC system is a closed system, so the fact you have to put more Freon in, means there is definitely a leak. I would check it out with a mechanic.
Apr 26, 2015 | Plymouth Cars & Trucks
Magic chef mcbr175b needs freon how to put it in
You will need a technician to do this probbaly but you can buy a self piercing fitting that you can install on the freon line and thne if you have the equipment you can add freon to the system this way.
Sep 12, 2014 | Magic Chef Refrigerators
I tried to fill ac system and compressor was cycling then just quit cycling and ac light on instument panel is flashin
probably to much Freon! when adding Freon always put a/c to its coldest setting and make sure its on max!
Aug 15, 2013 | 1994 Chevrolet K1500
Were able to fill the a/c with freon but it would run out in a day or two. Tried putting stop seal in it, but the freon cylinder wouldn't puncture, so we could not put freon in right away like it...
The system at this point is shot. The dryer is contaminated with oil and will not function correctly even if the leak were sealed. The system will have to be evacuated , flushed and leak tested, repaired and recharged.
Oct 04, 2017 | 1998 Ford Mustang
HI MY NAME IS TONYA WE HAVE A AIR CINDITIONER PROBLEM COMPRESSOR WAS MAKING NOISES LIKE SQUEAKING SO WE GOT A NEW COMPRESSOR, EXPANSION VALVE, ACCUMULATOR PAG OIL46 (10 OZ) 134A FREON (4 CANS) REMOVED...
HI there #1 before you put freon in did use a vacuum pump and pull too the right vacuum
specification if not you have air in the system.
#2 if you put 4 cans of freon you over charged the system must vehicles a/c systems use 1lp 5oz
you must remove freon first and use vacuum pump and put system in vacuum for abut 1hour
too mack shore system is air and muster free.
ones that is don you can charge system be careful not too over charge OK
good luck
ziggyone
Jul 03, 2011 | 2006 Dodge Grand Caravan
How do i put freon in my 1988 chevy s10?
Just start the engine and run your a/c. connect the hose (this hose is probably one you bought at the auto parts store along with your freon.) Relese the freon by screwing the object that is attached to the top of your freon can in and then out. Let the freon completely **** into system. You will know when your system is at the opporating level when your compressor stops clicking on and off and stays on. Most systems take only two 16 ounce cans of freon to be charged.
Jul 06, 2010 | 1988 Chevrolet S-10
My air conditioner is not blowing out cold air. How much freon do I put in a 2000 GMC Sonoma ?
That all depends how much freon it still has in the system, best way to check is with some a/c gauges, if you put to much it will not cool or could damage some thing, and if not enough will not cool right, used a/c gauges for right amount of freon, now if the a/c system is empty it takes 1.88lbs of 134a freon.
May 27, 2010 | 2000 GMC Sonoma Extended Cab
How to refill freon gas into a compressor of a refregarator?
Unless you have a line tap valve you cannot get into the system, The question is why?. Do you want to refill with freon?. Have you had a leak?. If so has it been repaired?. If it has do not forget to put the system under a deep vacuum first otherwise there will be moisture in the system and this will freeze at the expansion point creating a high pressure before it causing the compressor to cut out. Let me know why you want to put freon in first. then I may be able to help.
May 15, 2010 | Kenmore 50522 / 50524 Side by Side...
I put freon in my car, but the air compressor didn't kick on i was told that ut wasn't my compressor because i couldn't move it freely with my hand. what else could be the problem??????????
your compressor it operated by a pressure switch .. which is located on the system .. when you have enough freon in the system it lets the compressor come on .. are you sure you put enough freon in the system ? how much did you put in before you quit ? it holds nearly 3 cans.. also did it work last season ok ? askingn these questions to make sure something else didnt go wrong.. get back i have a few other things that might help if freon dont fix it .. Thanks Jerry
Apr 28, 2009 | Lincoln Town Car Cars & Trucks
Weather King 10AJA6001AH Air Conditioner Logo
190 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
