Question about Kenmore 63672 Convection/Microwave Oven
KEMS378GSS3 Oven Door glass
I have a broken interior glass on the oven door. I cant figure out how to remove the door. do you have instructions on how to remove the door from the oven and then change the glass?
  • jteglia May 16, 2009
    I tried to follow the diagram for removing the door - Lifted the door with both hands and pushed closed, but it does not seem to be working. Are you sure that is the correct way to remove this model?
    President:
  • 1,197 Answers
The door will need to be removed from the range and disassembled. Theinner and outer door halves are usually just screwed together and theglass held in place by a metal frame and more screws.
please refer the follwing link which gives a detailed analysis of how to remove the kitchen aid oven door...with pictures...
http://pdf.archiexpo.com/pdf/kitchenaid/built-in-electric-convection-oven/11406-3379-_21.html
u can get the oven door glass from the following website which also involves a detailed picture of the door assembly....
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=644736&ModelNum=KEMS378GSS3&mfgModelNum=&ManufactureID=3&Selected=Q4N3XECR&Position=6&mfg=Whirlpool&Type=&Mark=6
having said this.... do the oven door glass replacement ... only if ur sure what ur doing... otherwise get a repair guy to do the job....
thank you hav a nice day and stay safe.....
if u found my service helpful... please rate my service....
Posted on May 16, 2009
  • SAM JAYANTH CHANDRASEKAR
    yes thats the kitchen aid manual..... if the glass broke then there might be somepieces stuck in the mechanism........ check it out......... or else..... get a repair guy to do it for you.......
    thank you
    good luck
Replace inner door glass in a Maytag CWE900 built-in oven?
There is a poor diagram on Searspartsdirect.com, but no instructions. A diagram might help.
Feb 18, 2015 | Maytag Microwave Ovens
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Oct 09, 2009 | Bosch Microwave Ovens
The handle on the door has broken at the bottom. It looks like an easy fix if I can just figure out how to get it apart without breaking it further.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door. If the model number you have this listed under is correct, I found a replacement door handle at repairclinic.com for about $25. Look for item #1381096.
Sep 25, 2009 | Frigidaire FMV157GM Microwave Oven
Handle broke off my GE Advantium 120 microwave door (model #SCA1000DCC03). I just ordered a replacement handle (PRT #WB15X10071) but I need instructions on how to replace it. The screws are hidden inside...
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Sep 16, 2009 | GE Advantium 120 Convection/Microwave Oven
Broken handle on Spacemaker microwave
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
Sep 08, 2009 | KitchenAid KHMS147 Microwave Oven
The door handle is broken on model khms 105ebl0 kitchenaid
Sep 04, 2009 | KitchenAid KHMS147 Microwave Oven
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
KEMS378GSS3 Door has lost tension
Please find the diagramatic presentation for the replacement or removal of the door.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/0330c966a25780ac8525740c006f9000/$FILE/4317430.pdf
Do not be worried about the model if its exactly not the same as the basic removal process is 99% similar.
Thank You
May 15, 2009 | Kenmore 63672 Convection/Microwave Oven
Kenmore 63672 Convection/Microwave Oven Logo
74 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
