Question about Philips DVD625 DVD Player
DVD unit door does not open - Philips DVD625 DVD Player
  • alehome May 16, 2009
    Thanks. We'll try it and let you know how it goes.
    President:
  • 814 Answers
Check you owners manual for the emergency door release function and use it to open the door. usually thisis a small pin heole to release the mechanism, it could also be a slot under the unit. If this does not work , then take off the top cover of you unit and check the dvd carriage for possible dirt and obstructions, that are preventing the dvd drawer from working properly.ou can have a broken belt or some other out of alignment problems. While the unit is open you should clean out the dust and debris with a small brush and compressed air cleaning the unit . This will help in the unit over all operation. Hope this helps you with your problem.
Posted on May 16, 2009
DVD door will not open
Some one is going to have to open the unit up and see what is happening, something jammed or out of position etc.
Nov 06, 2012 | Televison & Video
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
The machine will not open the DVD Drive. When I push the eject button the display indicates "OPEN" but nothing happens. Is there a way to open the drive manually?
No,if u forced it,will damges the little motor that help it to open the dirve door.Unplug the unit,hold the unit in ur hand tight over head shake it a few times,this will help,what caught inside that stop the drive door from opening.Wait like about an hour later to replug it back in the unit,will be resetting itself back to the factory setting,will help help the unit too.
Dec 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
The dvd door will not open
Hello there:
On some of these units there is a very small hole that you can stick a paperclip into and press in and the door will now open if not unplug the unit and press the open button and hold it in while plugging it back in this should get the door open for you ok
best regards michael
Oct 26, 2009 | Emerson Televison & Video
Drawer won't open on my sanyo vhs dvd
check the front of your dvd has it got a small hole located on the facia just below the draw if so unplug your unit and insert an unfolded paper clip in to this hole as straight as you can you will meet some springy resistance that is the door locking mechanism push gently and the door will open .. once it has leave the door open and power up the unit the door should close and reset ... oh and make sure your kids ( if you have any ) havent dropped any M&Ms or stuff into the draw common problem Kids love em ?.
Regards Vortash
May 12, 2009 | Sanyo Televison & Video
I have a Toshiba SD2019U DVD player and the door won't open. When I turn it on, it makes a rumbling sound and displays "opening", then continues to rumble then changes to "closing" and...
i think there's a broken or loose gear.or someone put something small that stop the door from openning.
you can try to open the unit up and turn the power on
and check what hinders the door from openning.
May 08, 2009 | Televison & Video
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Philips DVD625 DVD Player Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
