Question about Air Tools & Compressors
My air compressor seems to be tripping my breaker when i turn it on. i used to tap the top of the contact switch case and it would free up. now i cannot get it to do anything but trip my breaker. maybe a coil needs replaced. contacts stuck. im not sure. its a single stage 6hp upright oil less unit.
    Sergeant:
    Champion:
  • 226 Answers
First make sure your on at least a 20amp circut then plug into it directly.if that doesn't do it.if that doesn't do it you can get by the old scool way using very fine sand paper and clean very lightly till you can get a new contact box,also make sure your wire leads to the contacts are snug and clean.
Posted on May 26, 2009
Is there a fuse or breaker on a Panasonic CW1803SU Air Conditioner?
If there's no power up on the unit, you can check your breaker switch box to see if there's any tripped breaker switch. If so, turn it off, and turn it back on. In some cases a sub-panel is installed somewhere else to provide power to the unit. Normally that's where the breaker switch will be in that scenario. If after doing that it keeps on tripping it, or it just won't power up, then you might have some electrical components inside the unit that might be damaged, like a capacitor, or the compressor itself. Sometimes when the compressor breaks it stops turning and overheats, causing other parts to burn also. To fix this you will need to call a professional.
Jul 07, 2014 | Panasonic Heating & Cooling
Keeps tripping turning off Put new compressor New compositor New breaker Still making a horrible knocking sounds n then trips
call the service co. who replaced compressor . they ether got a defective one or never replaced yours . (compressor is a motor and a pump sealed in a metal can suspended in oil on springs ) apparently yours has a broken one or more springs .allowing electrical field windings of the motor to come in contact with the case shorting out your breaker. solution new compressor!
Apr 04, 2014 | Heating & Cooling
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
My compressor quit working when i flip the on switch it does nothing any ideas what is wrong???
If the tank is full (pressurized): Nothing will happen when the switch is turned on. Bleed some air from the tank to see if the motor turns on when the pressure drops.
If the tank is empty or low on pressure: First check the circuit breaker to the outlet the compressor is plugged into. Next, somewhere on the compressor, usually on the motor, there is a circuit breaker. They are usually a small round white or black button that if tripped will stick out about 1/4 inch or more. Push that back in and check to see if your motor runs. The usual reason for these circuit breakers to pop is because the compressor is being run on an extension cord. Rule of thumb for compressors: run longer air lines, NEVER use extension cords. If it is absolutely necessary to run an extension cord it should be 10-guage and no longer than 25 feet.
Jan 31, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
My craftsman conpressor is a 5 gal type oil free. problem is when I plugged it in to operate it the moment I turn on the switch, it would run a few seconds and tripped my circuit breaker in the house for...
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Does it seem to run OK for as long as it runs?
Oct 26, 2009 | Craftsman Air Tools & Compressors
Breaker switch tripped when ac compressor engaged
The power strip is rated too low for the wattage of the unit and that causes the breaker to trip. I would be better for the unit if it were plugged directly into a wall outlet, because there is less a chance of voltage drop which would burn out the unit. They will only tolerate 10% voltage drop before getting into trouble.
Jul 02, 2009 | Fedders A6P09S2A Air Conditioner
My goodman compressor fan isn't turning since breakers thrown in box. mfg CR34K6PFV220 could this be a silonoid or perhaps something blown in the unit I can fix??I can't seem to get the case off. I do have...
turn tsat off and try to turn fan blade with a screwdriver through the shroud on top if does not turn freely motor locked up. there is a capacitor in the electrical section usually round with three sets of wire terminals on top if top is is dome shaped part is bad may have to look close to notice dome shape you reset breaker by turning breaker off then back on if it trips again very bad news 80% of the time
Jun 04, 2009 | Ruud UBHC Air Conditioner
Breaker keeps tripping
Your compressor could be going bad. You would need to check to amp draw on the the leads coming out of the compressor. There is a maximum rating listed on data plate. Something simple could be that your condenser the out side part of the unit is dirty. All you have to do is turn off the shut off switch out side, get a hose and some dish soap and wash the coils. Be careful with the water presssure not to bend the fins. Or some thing even a lot of techs look over is the breaker is bad.
Jun 09, 2008 | Ruud Central System Air Conditioner
Air Tools & Compressors Logo
94 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
