Question about LG LHD45EL Dehumidifier
LG LHD45EL Dehumidifier Icing Over
I have this dehumidifier in the lower level of my house. A very thin layer of frost develops initially over the entire coil when it is started, starts at the top and proceeds over the whole coil rather quickly. It then seems to disapate. However, after it has been running for 12-24 hours, I can come back and the thing is covered in a thick layer of ice. So thick, that it will actually push the front cover off. The air fitler and coil are both spotless and air flow is fine. The temperature is always over 68-70 degrees. Is there a switch somewhere I need to replace? Something that's not triggering the refrigeration to cycle? thanks for your help.
Aaron
  • aaronshort89 May 16, 2009
    Tomsat69,
    What is the temp control, where is it located and where can I find one?
    tomsat69,
    The unit I have is completely electronic at the control panel. There are no manual controls other than the electronic buttons that control fan speed and desired humidity level. I'm still not quite sure what you are referring to. Do you mean the actual circuit board for the control panel that's mounted to the back of the front cover?
    Sergeant:
    Champion:
  • 219 Answers
The only thing you need to replace would be the temp control it sounds faulty hope this helps :).I had the same problem with mine and that is what went wrong.
Posted on May 16, 2009
  • 1 more comment
  • tom wright
    tom wright May 16, 2009
    The control is where you turn on the dehumidfier on low and high that is depending on what type of funtions you have is it a manual or electronic control?If manual unplug the unit and remove screws around control panel and there should be a tube coming from the control you need to change .And that is the temp control.you need.Hope this helped:)
  • tom wright
    tom wright May 21, 2009
    if it is all controlboard there is still a humidity sensor on it.All dehumidiiers have one.Not to sure with your model If you cheak online by typing the brand name and find a parts break down hope this helped:)
  • tom wright
My LG LHD45EL Dehumidifier can't collect water in bucket, which part is failure and how to repair it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 08, 2011 | LG LHD45EL Dehumidifier
Lg dehumidifier does not pick up any water or humidity?
heatman101
Jul 31, 2010 | LG LHD45EL Dehumidifier
Humidifier is icing up during operation
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
vbn
May 20, 2010 | LG LHD45EL Dehumidifier
Ice forming on the to
Usually this happens for one of two reasons: 1) there is a problem with the refrigerant and/or compressor (like a little leak of refrigerant)
2) the room that the compressor is in is too cool (below the operating range of the dehumidifier)
If the unit is under warranty, call for service if you know the room is above the minimum operating temp. If it is a problem with the refrigerant, they will probably replace the unit.
I hope this helps.
(we have an LG dehumidifier and had to have it replaced when it was less than a year old - it was icing up in the summer. It still iced up in the winter (at times due to cold in the basement).)
May 01, 2010 | LG LHD45EL Dehumidifier
Dehumidifier icecing up
Three possibilities for coils icing up.
1. Low ambient temperature in the area where dehumidifier is located. If so, shut down and de-ice it. Then move the unit to a different - (warmer) - location and start it up.
2. Heating element - (which cycles periodically to liquify frost on the coils and allow water to drain) - is malfunctioning.
3. Low refrigerant level in the unit.
Sep 25, 2008 | Eva-Dry EDV300 Dehumidifier
LG LHD45EL Dehumidifier Logo
791 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
