Question about Bosch Washing Machines
Wont do the drain cycle and lost manual want a copy of manual
My front loader Bosch Maxx 800 Model Number WFL1660AU/04 will not drain i want to check the back but have lost my manual to see where to look do you have or send me in the right direction for manual or know what the problem might be. Ta Shay
  • shaynjohnc Jun 25, 2009
    Thanks will try that and see how i go hopefully that fixes it.
    Cheers
    Shay
I have a Bosch front loader as well that experiances the same problem. My machine does not have a "trap" that catches lose items; ie. change and I have found that these lose articles find themselves getting stuck inside the pump that pumps the water out. My machine would make a loud "clickety clank" noise if the change was smacking around in the pump which would eventually turn into a very loud drooning noise when the change jammed the motor. If this is what you are experiancing along with the lack of water drainage then your pump has either stopped working, the impeller wheel is jammed, or the flow of water is obstructed.
Try checking the pump and related hoses for blockage. All you will need to access these area's are common hand tools and I believe either torx or hex head drivers. You will have to remove the back of the machine to access. Once this is done, you will see all the rubber tubes. My pump was located at the front right side of the machine underneath machine barrell. Remove it, then take apart (only a few philips head screws) and check for obstruction.
Hope this helps.
Posted on Jun 24, 2009
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
I am living in Spain and want to know how to obtain a User Manual for a BOSCH MAxx WFL 2462/04 front loading washing nmachine. Thanks, Piers Armstong.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 14, 2011 | Bosch Axxis WFL 2060 Front Load Washer
How do I wash delicates, which drawer, what soap or detergent, etc., front loader Bosch machine, bought recently, (lost manual).
WAE18060AU im leaving this on this page becuase it is a model number to a maxx classic the look up site is currently down for maintenance ill message you back in about 6 hrs Rick
Jan 15, 2011 | Washing Machines
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Feb 06, 2010 | Bosch Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
416 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
