Question about Esky Honey Bee King 2 RC Helicopter
I had an accident, and over the winter i replaced all the plastic with aluminum. i got everything together and wanted to adjust the pitch. when i plug the battery in the light blinks and stops. i move the throttle and the servos adjust but i get no motion with the blades? i have only flown it once before the accident. i need help
  • 3 Answers
Go to www.helifreaks.com for any answers to your heli probs and questions. Note you have to register before you can post but the people on there are friendly, helpful and informative.
Posted on Jul 13, 2009
Where do you usually find the answer to your questions? in this box?
I can't see the "box" you are referring to! It is cardboard, or made of wood, or plastic, or steel, or aluminum, or some other material?
May 15, 2017 | Winter Sports
My 2005 trailblazer cuts off when in gear when the defrost/ac is turned on. Just had a brand new transmission put in the day before this started. Would that have ANYTHING to do with this happening? What...
VERY easy fix, and a VERY common problem. When they put the new tranny in they had to unhook the battery. When the battery is hooked back up, computer thinks everything is clean and adjusted well. Problem is, your throttle body is dirty, so the computer isn't adjusting for fuel correctly because it thinks it's clean. Rip that throttle body off with the battery disconnected, it's only 4 bolts and disconnect the wires. Clean with Seafoam or throttle body/sensor safe cleaner using towel or toothbrush. Do NOT use wire brush, will mar the aluminum. After everything is clean, put back together and hook the battery back up. With all HVAC OFF, drive around for 15 minutes or so, so the computer can relearn all correct settings. Problem solved, should clean the TB on a regular basis. By the way YES you can reuse the hard plastic gasket on the TB. $7 fix if you do it yourself. Good luck!
Feb 23, 2015 | 2005 Chevrolet TrailBlazer
How do i remove an ignition in a gmc jimmy 2000 without a key?
Hello, Dan. First, disconnect the negative (-)/ground on the battery Dan are you mechanically inclined. If not then don't attempted this job.
You will need to remove all the plastic covers on the steering column. Remove the horn ring.--two screws under the steering wheel. Remove the horn ring and disconnect the horn plug. Remove the steering wheel nut. Use a steering wheel puller to remove the steering wheel.
Remove the turn signal switch that fit around the upper part of the steering column. Then remove the some of the parts that are associated with the steering wheel and/or column.
Now, look at the ignition switch flange, it a big chunk of aluminum. Now look for a large aluminum dowel pin 5/8" in diameter that is driven into the chuck of aluminum but it is parallel to the steering column.
This aluminum dowel pin will have to be drill out before you can get ignition housing off, If there is adjustable steering column lever, remove this also.
Now, once the dowel pin has been removed, looking for a **** in the ignition housing. Take chisel and insert into this ****, drive the chisel into the **** until the ignition housing is loose to be remove by sliding it up over the steering column.
If you buy a new ignition switch, on purchase the switch with keys. Don't buy the hole new ignition housing.. If you do it will get expensive.
In the ignition (old) housing drive out the ignition switch pins that keeps the ignition switch in the housing. Install the new ignition switch re-insert the ignition switch hold pins.
I am fairly sure that Carquest/ NAPA some other larger auto parts will have ignition housing bolt. If they try to sell you a replacement aluminum dowel pin don't buy it. It is almost impossible to install the aluminum dowel pin without the proper tools, so use a bolt to squeeze ignition housing together.
Before putting everything back together. Now, check the new ignition switch to make sure it works. I wish you lot of luck. GB...stewbison
Sep 27, 2011 | 2000 GMC Jimmy
Our Technics SL-1200MK2 has issues with the direct drive. It does not spin at a constant speed. When stopped, it does not stop immediately. What can be done to solve this?
To adjust stopping speed you'll have to remove the plate by pulling it up. Then there is a plastic cover that has some screws, remove the screws and remove the plastic cover, you'll find a variable resistor that reads something like brake. Adjust it to the left or to the right with a screwdriver and see at which position works best.
To solve the constant speed problem you'll have to replace the pitch regulator.
Go to any panasonic/technics service and buy the pitch. If you have a bit of soldering skills you'll be able to replace it by yourself. You can access the pitch regulator unscrewing all the screws under the device and then removing the cover.
Hope you can solve the problem!
May 18, 2011 | Technics SL-1200MK2 Turntable
My 96 jetta 2.0 is leaking oil from the top of the oil filter mounting area where the water hoses connect to it.it looks like it has two or three pieces bolted together might be plastic.can I take apart...
The oil is most likely leaking from the oil cooler seal. The oil cooler is the square aluminum piece that the oil filter screws onto. To replace the seal, remove the filter, remove both coolant hoses that attach to the cooler, remove the nut that secures the cooler to the block and slide the cooler off the tube. Replace the rubber o-ring seal which is available at the VW dealer. It's inexpensive. Replace everything in reverse order. Good luck
Dec 31, 2010 | 1995 Volkswagen Jetta
How do you adjust the clutch on a 1991 mustang?
if its hydraulic then adjuster is under the car if a cable it may be auto adjust on the pedal ,but some fords done away with this and their is a allen key headed bold on the pedal shaft about half way up the pedal
Jun 14, 2010 | 1991 Ford Mustang
I need to adjust my clutch but it seems like the adjuster by the pedel wont stay clicked in the spot i want it in
Unfortunately the plastic stock adjuster doesn’t allow for precisely adjusting the clutch cable.
You can purchase an aftermarket adjuster that mounts on the fire wall that enables you to adjust the clutch cable to any position you choose. It also eliminates the rubber grommet on the clutch cable that gives the cable a firmer feel, which improves shifting dramatically.
Steeda, UPR, BBK & Ford Racing all offer one.
Another improvement is to change the plastic adjustable quadrant to an aluminum quadrant eliminating any deflection during hard shifting.
Hope this helps.
May 20, 2010 | 2002 Ford Mustang
When I play the sound come out distorted, like it untunes. any idea what is causing the problem? this is a for a Korg X50 and is only 2 yrs old. not korg Ma30
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Aug 19, 2009 | Korg Ma30
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
Esky Honey Bee King 2 RC Helicopter Logo
118 people viewed this question
Top Esky Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Esky Toy Expert? Answer questions, earn points and help others
