Question about Acer AL2671W 26 in. LCD Television
Plasma screen i have two black stripes from top to bottom of my plasma screen how do i remove them
  • 3 more comments
  • squompy Nov 04, 2007
    fwljkaslifupaiuhv;ajbrnv
  • Anonymous Dec 16, 2007
    i have two black stripes on my plasma screen 7 inches from the botton to up how do i remove them the model is zenith p50w28a
  • Boradakota Dec 30, 2007
    two black striper 10 inches apart from top to middle of screen
  • Anonymous Oct 07, 2008
    I have a single black stripe about 11/2 inch wide running vertically from top to bottom of the screen. It is a 2002 vintage Fujitsu 42inch plasma. Have had no problems until now. Hope it can be fixed.
  • tgp-marcorr Oct 31, 2008
    i have a tv akira.it has a two black stripe on top and below the screen.i dont know how to remove them.i try to fix it using the remote control but it doesn't work.can get the service mode of my akira tv?
  • 22 Answers
These 2 solutions are totally ridiculous and not helpful at all.  Embarrassing in fact!
This totally fixable, go to the following link at read it and follow carefully.  I performed this fix before I even found this thread, but since it has a better decsription than i could provide, i will just point you in the right direction.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
*any one with Black Bars running vertical in their Plasma Tv*
so called experts say this problem is the address buffer boards that run along the bottom on the rear of the screen.......my experience as a service engineer for leading manufacturers is that the PDP module iitself is faulty(IC's on the ribbons bonded to the glass can blow)......if this is the case then get ready for a very costly repair if the tv is out of warranty!
Posted on Nov 04, 2008
    Scholar:
  • 51 Answers
Peel off the black tape?
Is this still covered by warranty?
If one expects help here then one should quit being lazy.
Brand names, model numbers, age, has it had anything spilled in it lately, been moved, and any and ALL other details you can provide!
But, a possible cause is power supply circuitry, possibly electrolytic capacitors. Remove covers, unsolder, and replace.
Or call a tech.
Posted on Oct 16, 2007
White stripes on plasma tv screen from top to bottom all across display, picture is still visible.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Televison & Video
My nec 42" px-42vr5w plasma
Despite the fact that you have posted this as a question about a kitchen range, I can tell you waht the problem is anyway!
The plasma screen is controlled by hundreds of seperate connections at the top, bottom and sides of the screen which use electrical pulses to signal the pixels on the screen what colour they should be. If the connection to a bank of these connectors fails (in this case either at the top or the bottom of the screen) then they will usually die and that portion of the screen most commonly goes black. Next most common is that they go white as yours has.
This is absolutely NOT a DIY fix. You will need to get it to your local TV shop. If you're lucky, they will find and fix the poor connections. If you're unlucky, the plasma panel has had it and they won't be able to repair it. A replacement panel supplied and fitted is probably about the same price as a nice new, updated plasma TV, so if the issue goes that way, consider scrapping and buying a new one
Jun 23, 2011 | Kitchen Ranges
My samsung 50 inch plasma tv has a black and white 2 inch stripe from top to bottom one third from the left side of tv our tv is about 1.2 years old is there a addjustment to be done ? thank you from mike
Image retention, Go to Menu and I believe pic settings go to the Burnin Scrolling feature..Will run white and black in full screen, run for an hour problem huold be solved..Happened to mine and the scrolling feature got rid of it.
Mar 15, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Black vertical stripe on screen
hello,if the stripe goes completely thru the screen top to bottom,you most likely have a defective plasma panel. Other instances will require substitution of the drive boards(c boards) and rarely the control board.
Jun 02, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Nov 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
Apr 05, 2008 | Televison & Video
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Acer AL2671W 26 in. LCD Television Logo
142 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Jaime Hernandez
Marvin
Marvin
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
