Question about Bryant 462AJC021BA Air Conditioner
The electricity in the house went off briefly. the air was not working. I turned the breaker on the furnace off and now it will not turn back on - it is like it is stuck
  • 585 Answers
It sounds as though the interruption caused a resultant surge when the power came back on, damaging the breaker.. You won't know if anything else is wrong until the breaker is replaced. You may want to consult an electrician for replacement of the breaker if you don't feel confident with the job. Don't take unnecessary chances.
Posted on May 16, 2009
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
We have just had an electrician do work around our house when we went to use the airconditioner it doesnt work. Tried to call our electrician but of course no answer. Any ideas how to start my...
Check the electrical panal and make sure the breaker is on(220 volt 2-piole breaker). Check at the air conditioning unit and make sure the disconnect is on and there are fuses in the disconnect. Some disconnects are a non-fusible type. Turn the breaker off at the electrical panal and make sure the fuses at the disconnect are good. Also check and see if the switch at the furance is on. Or check the electrical panal and make sure the breaker for the furnace is on(110 volt single pole breaker). This is only if it is a split system type air conditioner. Part insude , part outside. You need control voltaged (24 volts) from the furance to the outside contactor at the air conditioer for the system to operate.
Jan 27, 2011 | Mastercool 67680 Evaporative Cooler Air...
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
Furnace is not turning on
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Jan 10, 2009 | Heating & Cooling
Electric Furnace
There could be a small fuse on the cotrol board
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Furnace will not light, but there is gas to the house
This problem will need to broken down in several steps. First, reset all the breakers that operate the furnace and ac. Turn the thermostat to on and the ac to off and see if the furnace blower starts. Get back with me.
Aug 12, 2007 | Haier HWF05XC5 Air Conditioner
Bryant 462AJC021BA Air Conditioner Logo
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
