Question about Netopia 3-D Reach (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter
Netopia 3d reach will not acquire ip address
I have installed netopia 3d reach and have input the correct wep key when prompted, but it will not acquire an ip address from my linksys router. Please help.
  • 83 Answers
Make sure that DHCP is turned on on the router. If it is, reset your router and try it without wep to check that it is working.
Posted on May 16, 2009
Where is wep key location
WEP key is in your router's configuration settings.
in windows open a command prompt (search for "cmd" from the start menu)
in command prompt type "ipconfig"
Look for "default gateway" and remember the ip address listed for it
in your browser (internet explorer, firefox, chrome) type the ip address from the default gateway into the address bar. probably something like 192.168.0.1
once you access the router settings, the WEP key is under the WIRELESS section, called security.
Aug 12, 2014 | Linksys Computers & Internet
How do i find my Wep key for my netgear router
you have to access the GUI of your router. if you dont know the ip address. go to command prompt and type in ipconfig. look for the gateway ip address and type it directly to your I.E address bar. once you are inside the router interface, ussually WEP key is under wireleess security. go over there and check your WEP key. you can also change the WEP key.
Apr 03, 2010 | Computers & Internet
How do i install the netopia 3d reach?
you can install it via disc which is provided to you........insert that disc there u willl find the option or icon by name setup......click on it and follow the instructions.....your software will be installed........
or you can directly install it from internet....
Aug 11, 2009 | Computers & Internet
Cannot acquire network address but sees router
You can first disconnect ur network name form router and then give a static ip in the range of the router on the wireless n/w connection of ur computer and then try to reconnect. Computer will automatically pick up the address and get u online, if problem still persists then reboot the comp once.
thanx and regards
sukhiii
Jul 24, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless lan card
The full guide by Motorola to installing the Netopia card can be found athttp://netoctopus.com/support/hardware/manuals/3DReach_usb_install.pdf
You will need Adobe PDF reader to view it.
May 26, 2008 | Netopia 3-D Reach (TER/GUSB-N1)...
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 3-D Reach  (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter Logo
300 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
