Question about Refrigerators
Water reservoir and its lines freeze up. will not despense water.
I believe that the cold air from the freezer coming through the small vent into the refrigerator is not circulating right. The food on the bottom shelves is freezing. Top shelves are barely cold. I think i'm missing a cover for the light in the back of the refrigerator that may deflect the air causing it to circulate upward and cool the rest of the refrigerator. Any suggestions are very much appreciated.
  • stanleyelkin May 16, 2009
    Thank you Vic for that quick response. Do you still think that the cover over the light in back would help since it should be there anyway?
  • stanleyelkin May 18, 2009
    It was good advice Vic. I had previously been told to follow that same advice, is the only reason that it did not solve my problem.
    President:
  • 1,136 Answers
HI, Make sure the evaporator fan motor in the freezer is running. Check and make sure both of you temperature controls are set to normal settings. YOu're right, it is an air flow problem. Make sure there isn't any frost building up in the freezer. Let me know if any of these help or if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
  • Victor
    Victor May 16, 2009
    It certainly wont hurt. If I had a model #, I could look it up and get you part # and how critical it would be. Let me know
  • Victor
    Victor May 16, 2009
    Hi, Can you tell me why my answer was inappropriate so that I can better myself to help others?
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The bottom shelf of my upright freezer is super cold - makes everything freeze ''dried'' and super frozen. Why? Seal is good (it ''sucks'' shut and is hard to open after that) - rest of the freezer freezes...
if you are not getting the desired temp in the freezer with the temp control knob, partially block off a small portion of the vent at the bottom with some tape. You could do the same with the vent at the top, the idea is to create a small air restriction. also if you dont add warm product to the freezer very often it has little heat to remove. you may put a gallon jug of warm water in it periodically.
Nov 26, 2009 | Heating & Cooling
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
No water thru door
Sounds like the door area heater is not working and the tube is freezing up in the door near the dispensor. Try turning off the unit for a day with the door open to see if it suddenly starts working again. That would lead you to believing it was a freeze plug. Rarely does the line kink in the door.
Oct 29, 2006 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
