Question about Mitsubishi WS-73905 73" Rear Projection Television
Can't get any remote to work for my Mitsubishi WS-7390573
Just bought the used TV mentioned above. I tried a bunch of universal remote with no luck. Then bought a remote online from NRI, which they said should work. It did nothing. Any suggestions on what to do. Afraid sensor maybe bad on the TV or something. I know there is a chance the remote NRI sent me that has BRMI1 on the back is not a match. They mentioned that it was not the original remote, but it was not a universal and should work. They called it the best replacement. I put a bunch of different baterries in but never could get any lights or anything on the remote to do anything so I am guessing it is a bad remote they sent or my tv sensor is bad. Any thoughts on this.
    New Friend:
You could always download a universal remote app from Google Play that should work. Hope this helps you
Posted on Apr 01, 2017
  • 934 Answers
SOURCE: Mitsubishi Big Screen TV VS 4542
No, just get a miracle remote for Mitsubishi and problem solved... We have several here in the shop and they will operate EVERY function of the original at a fraction of the cost..
Posted on Dec 10, 2007
  • 927 Answers
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Posted on Sep 01, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Posted on Nov 27, 2008
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
Hello, My name is Gennefer. My boyfriend bought me a lovely Mitsubishi WS-55313 65" Rear Projection TV from a yardsale that just so happened to NOT HAVE THE ORIGINAL REMOTE, AND IT JUST SO
Someone setup the parental restrictions.
The remote you can look up and most likely order off of Amazon using the brand and model number...
You'd have to somehow convince Mitsubishi to give you a "universal code" or other override or much easier, usually, get the code from the people that you bought it from...
Feb 23, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Tv remote codes free
Feb 03, 2014 | Mitsubishi WS-48311 48" Rear Projection...
I need code for a mitsubishi 65 in tv model no ws 65869
Five digit universal remote codes for Mitsubishi TV are:
11250, 10093, 10150, 10178, 10836
Four digit codes are:
0005 0151 0051 0004 0009 0254 0022 0141 0180
Three digit codes are:
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Wish You A Happy and Prosperous 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Sep 28, 2011 | Universal Remote Control 10694 Remote...
Mitsubishi tv ws65613 and remote wont work
You could try a replacement remote from
You will need an original or the replacement to access some of the features of your television
I hope that this helps.
Oct 12, 2009 | Mitsubishi WS-65613 65" Rear Projection...
WS-55809 with Universal Remote
you will have to get a new mitsu remote in order to make the adjustment. Most universal remotes are made to just do basic functions, unless you start getting into nice sony touchscreen remotes but then they cost 100 by themselves.
the remote to a mitsubishi wd55513, wd65513 etc will also work on this set, I have done it before.
Here is one on ebay:|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Dec 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Where can I get the remote control for Suzuki XL-7 DVD player
Had the same problem. My wife went to a car audio place and bought the wireless headphones, I think they were cheaper. And I just bought a universal remote from Radio Shack, its a Radio Shack brand little gray remote. It was 9.99. You have to use the "search for codes" option in the instructions. I can turn the tv on, off, stop, play, skip, all that stuff.
Nov 14, 2008 | 2007 Suzuki XL-7
Mitsubishi WS-55807
Good Day, betsy;
Check all cables and try to reset by un[plugging for 3 to 5 minutes(from wall), plug back into wall.
Jul 28, 2008 | Mitsubishi WS-55807 TV
Need remote codes
need code for remote
Jun 01, 2008 | Sharp 20L-S100 20" TV
Dec 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-73905 73" Rear Projection Television Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
