Question about Pioneer PRO-620HD 58" Rear Projection Television
Split screen question
I have a Pioneer Pro620HD tv how do i watch digital cable and regular tv channels on split screen ?
    President:
  • 788 Answers
To get a split screen working on this set, you will need to do the following steps.
1. Put a splitter on the incoming cable.
2. One side will go to the digital cable box and one to the tuner on the television. (Ant A)
3. Hook the digital cable box using the video out from the box to Input 1 on the set.
That should do it now select your digital cable on Input 1, and then select the split screen source as Antenna A. You may have to switch sources to select a different input.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support.
Posted on May 16, 2009
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
I no longer have cable but I can not watch regular tv so how do I fix this
You now need a digital tuner to receive broadcast TV channels...if your tv is a regular tv , go to radio shack and purchase a>>>DIGITAL TV CONVERTER BOX< AND antenna.
May 19, 2010 | Televison & Video
WD-52525 split screen
what are you using as input? On this set only digital channels can be the main picture. You can try the exch button to see if it comes back right also.
Aug 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tuner problem? (hope not!)
check if you put the cable in tuner A OR B CHANGE WITH REMOTE MAY BE NEED GOOD CONETION OR PUT ONE SPLIT T CABLE AND RUN ONE CABLE TO TV IN A AND OTHER B CHECK THIS NOT TRAY SPEAK SPANOL THANK YOU
Sep 27, 2007 | Philips 51PW9303 51" Rear Projection...
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
Pioneer PRO-620HD 58" Rear Projection Television Logo
144 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
