Question about Frigidaire FRT18G4A Top Freezer Refrigerator
The frig part and the freezer part are not getting cold. They get cold every two days, then gets warm for two days and then it re-peats the cycle.
  • prpravin May 18, 2009
    i have bloomberg fridge on top freezer below refrigerator one compressor
    the fridge is working the freezer get colds the fan is working but it does make the items frozen
    last year we had same problem a repair person had said there was ice collection on sensor hence the problem and cleaned it and the problem solved
    same problem has happenend now ?/
  • Sudeep Chatterjee
    Sudeep Chatterjee May 11, 2010
    The outlet of the drainage pipe must be partially blocked with some organic material which is also following the freezing/thawing process thus only releasing when totally soft & refusing to do so when frozen..........sodeep
    President:
  • 1,136 Answers
Hi, check to see if both the fans are running or check and see if there is frost builing up inside the freezer. Are the condesor coils clean? These coils are located under the refrigerator near the compressor.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
5yr old frig not cooling,started noticing ice cream soft etc...over a 2 or 3 day period finally frig warming up as well.turned up the cold dial then it ran continually while getting warmer.We were tol
You need to replace the "defrost thermostat". Here is a link to the part you need.
Here is a video to show you how to replace the part. The model shown may be different but the process is the same.
Oct 17, 2012 | Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
I have an sqd26vw frig. Both the freezer and frig upper sections get warm, while the bottoms still stay cold. I unplug for two days, then it seems fine again for about one month. Any suggestions?
hi , your defrost is bad and your freezer build ice till no cold air can floe from the freezer to the frig section...
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today . com
  6. I hope you find this Very Helpful and best regards!
Jan 05, 2010 | Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Frig too warm, freezer too cold
if there is ice build up you have a defrost problem. either the heater bimetal thermostat timer or evap fan could be bad. you could also have a stopped up drain. if the coils get too much ice build up the air wont beable to travel through them and the bad air flow will cause the fridge to become warmer
Sep 16, 2009 | Frigidaire FRT8S6EMB Top Freezer...
Frig not getting cold
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
Freezer is at 38 currently has been climbing all day
Hi!!! Yes its normal dont panic just relax and have a cold soft drink..Nothing is wrong with your frig..Remember defrost cycle is 15-20-or 30 minutes depending on the frig..Good luck..Its all normal..
Jan 03, 2009 | Kenmore 72073 Top Freezer Refrigerator
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
281 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
