Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Uniden DECT 6.0 Phone battery does not hold a charge
Phone battery does not hold a charge and another battery does not seem to charge even with a different charger base
  • ken hammond Oct 30, 2012
    I have same problem, is there no solution?
SOURCE: uniden dect 6.00
handset dies or cuts off frequently during calls or when talk is pressed to answer even when fully charged and right in front of the base unit. Beyond frustrating.
If I hadn't lost the reciept, I'd return this useless phone in an instant.
Posted on Sep 03, 2008
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
cnavarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
goalie39
  • 469 Answers
SOURCE: After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Posted on May 05, 2009
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
Uniden dect 6.o cannot get off hold
Since you didn't give the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 08, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
Hello, I am looking to replace my Uniden cordless phone battery EXA14248. Do you have it??
I have searched various stores which carry battery replacements.I even searched uniden.com .We had the same problem with our old phone.Your phone seems to be outdated enough so that there are no replacement batteries.Us too.I think the makers do it on purpose to sell newer phones as much as possible.Wish I had better news but those are the facts.The new technology is DECT 6.0 phones which actaually works at 1.9 GHz.Kind of strange since the previous products were 5.8 GHz.But DECT is supposed to have wider range to walk around your house with,clearer sound and a couple of other "advantages".If you do decide to buy DECT,do some research.There are forums all over the web where people give opinions/reviews of ones they have already bought and are using.Just google DECT phones and all kinds of stuff appears.AT&T's seemed to have the better reviews but there are a couple of others which rated well also.I have had numerous Unidens,and you think they would improve,but I have been disappointed and will never buy another Uniden,however the decision is yours.Wish I had better news.Good luck! Greg
Aug 11, 2010 | Uniden EXA14248 Cordless Telephone
I have uniden Dect 6.0 dual handset. The second handset will not hold a charge even after several days in the base. The battery indicator says full but will not last long enough to even dial a number. The...
Is the phone under warranty?
You should check that the battery is a genuine Uniden one. (Check them all).
From personal experience - I had the same problem with a phone I bought (supposedly) brand new - though mine would last about 10 minutes. The batteries which came in the box were not genuine Uniden batteries. I had to buy new ones direct from Uniden (to be sure) - and no problems since..
I have since been told that sometimes the original batteries are stolen and replaced with cheap nasty ones - before they even get into the shop.
Same thing can happen with computer software - they make copies from the original cd. Then they just need a vacuum packaging machine to make it look like it has never been used.
Mar 28, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.o
What model Uniden DECT 6.0 phone/answering machine?
Mar 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
After 6 weeks, phone is dead
still warrentty time so contact ur uniden cordless phone dealer
Jul 19, 2009 | Uniden Cordless Phone
Cant register/install a new dect 6.0 uniden 2060 phone
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
724 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
