Question about Dishwashers
Can hear motor running but nothing happens in dishwasher
Motor runs but nothing happens. No water enters machine, no motion inside machine. Checked inlet screen, replacd flood saver supply line with a standard supply in case flood saver had tripped. Then discovered that nothing inside machine was moving when motor was running. Also cycle circuit breaking as I read somewhere that this sometimes will reset the control board. Any ideas would be greatly appreciated. Thank you in advance. Kenmore Ultrawash with quietguard model 665-1702403
  • dseason May 30, 2009
    Discovered inlet valve can be tested by 1) remove the valve, 2) put a hose on valve that you can blow thru 3) CAREFULLY connect valve to 120V while blowing through hose. It may "sound" like the valve is working but you must blow air through it. The valve defaults to the closed position and opens when volage is applied. Mine sounded like it was opening and closing but this was simply the solenoid clicking. No air would pass through the valve. Replaced the valve and all is working again. Thanks for the help.
    Scott
  • Anonymous Mar 17, 2014
    turn machine on can hear a motor running but no water comes into machine and controller does not move
    President:
  • 1,136 Answers
Hi, you need to test voltage to the water inlet valve. If you are getting voltage (120V) replace the valve. If you are not getting voltage check the water level switch located in the front corner of the tub.
If I can assist you any further with parts or part #'s, please let me know.
Thanks
Vic
Posted on May 16, 2009
  • ssatthi May 10, 2011
    Hi can u pls help. I have a Bosch sgv57t03GB which retains the water. I have checked the usual pipes and drains. I've checked the Elec board all working fine. Nothing open circuit. I swapped the solenoids over and there was no change. I suspect it's the pump. Is there any way of checking this? Also I could do with a technical manual any help with this ??
Whirlpool dishwasher du920pfgq3 will not drain
If you hear the drain motor running but water not draining then there appears to be a blockage in the drain sump or hose. Assuming your kitchen drain is clear you will have to check filters inside the dishwasher and worst the drain pump.
If you do not hear drain motor running then the drain motor needs to be checked.
Check part locations at this site
http://www.appliancepartspros.com/parts-for-whirlpool-du920pfgq3.html
Apr 22, 2014 | Dishwashers
Bosch SHU9925 motor is running but no water is coming in to wash
Check out the fill valve for proper operation.. If stuck, then no water!
Sep 11, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
Dishwasher arms do not spin
It sounds like your wash motor has failed to run at full speed to pump the water through the spray arms. The computer board will eventually report an "LE" error code for the motor's issue.
Jul 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
After water turns on, nothing else happens
If you are hearing a humm noise after it stops filling, your motor is locked up.
Jan 04, 2008 | Dishwashers
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Dishwasher will not go thru wash cycles
Hi
You have a problem which will need some knowledge of how the machine works and some test meter.There may be a problem with the motor.It may not beworking,jammed or dead -burnt out.The motor does the work after the water-cold,hot or medium-has entered.
The timer-you say works- will connect power to the motor to do its job,power to solonoid for the valves to open at the right time to let water in and out-pushed out by the motor.Remove the water with a cup and rags from the machine and then see if the motor turns by hand.This may mean you have to get under the machine.ALL WAYS REMOVE THE POWER CORD AT THE WALL POWER OUTLET--Jay
Nov 15, 2007 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwashers Logo
426 people viewed this question
Top Dishwashers Experts
