Question about Gateway Solo 1450 Notebook
Can not read disk error
Installed a used hard drive in my Sol;o 1450 and when it starts up i get an error message Can not read disk!
  • Gateway Master
  • 32,281 Answers
You can't install any hard disk from any computer and install it into your computer and expect it to work unless it came from the same model computer with the same devices that are installed on your computer.
When Windows is installed it configures the operating system unique to that computer and stores this info in the Windows registry.
To get a used hard disk to work in your computer, you have to install Windows as a fresh installation on your computer.
Posted on May 16, 2009
A DISK READ ERROR OCCURRED
Try Windows7 instead of XP, since XP doesn't support SATA drivers to read your HDD
Jul 08, 2014 | Biostar GF7025-M2 GeForce 7025 Socket AM2...
My computer harddrive has a problem
Causes of Disk Read Errors WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all Power and Data leads that attach from Motherboard to your hard drive, IDE,SATA make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd \ cd and floppy if applicable have secure dust free connections. Computers need all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error b> There are many different types of disk read errors that can show up on your computer screen during various usage efforts. Be aware as to what you were doing and what task your computer was attempting to perform at the time that the disk read error showed up. This may be a very simple issue, or it may become very complex and involve a data loss threat. Using the process of elimination for determining the error reason can save you time and money.
CD b> Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem. With any kind of disk read error, the best of luck will be that this is just a problem with a CD that you are attempting to use on your computer. To determine this, remove any CDs or floppy disks from your PC and reboot your computer. Wait and see if it turns back on without any error messages. If so, all is well and you merely need to check the CD you were attempting to use for damage. b> Windows Installation b> Sometimes a Windows repair will alleviate the problem of a disk read error. To find out if your error message is actually related to a Windows environment problem, get your Windows installation CD and reload the CD. Do not reinstall but rather choose the repair option. This might correct the problem. b> Hard Drive b> If the problem is with your hard drive, you will hopefully have previously created a mirror image to protect your data. If so, you can breathe easily because your hard drive data is safe and you can simply replace your hard drive if need be. If you do not have a backup and the problem is with your hard drive, you may need to use a recovery service or do further research regarding how to recover your data on your own. b> Reseat Your Hard Drive b> If the disk read error message does not come until your system has already completed its bootup, then it is probably originating from the OS (operating system). It is possible that your BIOS (Basic Input/Output System) is simply unable to locate the drive. Since the BIOS is responsible for the booting-up process, it will typically be the origination of the disk read error message. If this is the case, you may want to try reseating your hard drive. Be very careful when attempting this because you have to manually remove and replace the physical hard drive in your computer. b> Bad Spot b> There may just be a bad spot on a disk. Consider whether or not you received this message when you were attempting to access a rarely used file. Check to see if you receive this message after turning your computer off and on again and attempting to access a file that you commonly use. Using a disk error checker utility scanner will assist you in narrowing the problem to this if it is the cause. Hope this helps.
b>
Jan 03, 2013 | Computers & Internet
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
Ok so i have an acer laptop and when i start it up it comes up with "A disk read error occured press CTRL+ALT+DEL to restart" when i do that all it does is restarts and goes back to the...
There might be a problem in your Hard drive. If you have tried so, Try removing your hard drive and set it up again. If it still doesn't work.You may try using a recovery disk or the cd used to install the operating system. If still the error is appearing, try to reinstall the operating system. if still, I'm sorry you might need to replace your hard drive.
Aug 28, 2011 | Computers & Internet
On start up,there is a message that pops up,which says that,THERE IS A DISK READ ERROR.What does this means and how do I solve this?
I understand that you are having DISK READ error on startup. This error message may be due to BAD HARD DRIVE or a DEFECTIVE HARD DRIVE.
To do a work around, you can try to use a new IDE cable on the hard and try to boot the system again.
Jun 30, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Platstation 3 hard disk error
It should have formatted with your ps3, even if you formatted the HDD on your laptop it would have asked you the same thing, since the PS3 asks you that so it can install some folders for the pictures, games music etc.
your problem could be caused by faulty HDD installation, a faulty HDD or a broken ps3 that cant read HDDs anymore.
I would make sure the HDD is installed correctly, if that doesnt work I suggest buying a new HDD. If both of those dont work then you have a Ps3 that has a trouble reading HDDs
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
