Question about Dryers
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
    President:
  • 1,136 Answers
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
Posted on May 16, 2009
How do I replace the door strike on cabrio dryer 5600
Door strike or catch the strike is on the front panel which means removal of front panel
Sep 04, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Whirlpool dryer,model WED5300VW0 is snagging my clothes. How can this be fixed?
hello. You are going to need to inspect the bearing and front seal on the front of the drum, and also the bearing ring for front support. The rear of the drum is supported by two rollers underneath. First of all, here is a parts diagram for your dryer. On this first one, you can see the bearing ring for front support. Part number 36. It will need to be inspected for wear.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28263302#d28263302
The next thing that I would inspect is the front bearing and seal, which is part number 38 in this diagram. It will need to be inspected also.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513301&diagram_id=28129401#d28129401
When these things are worn, it can cause the drum to drop slightly and snag your clothes. In order to take a look at these things, your going to have to know how to disassemble your dryer.
You do this as follows;
Pull your dryer out from the wall to avoid hitting the wall when you raise the cabinet top. Lift the lint screen access cover and remove the two screws inside. Do not remove the actual lint screen before you remove the screws. Removing the lint screen first could lead to accidentally dropping the screws down the lint screen shaft and into the blower wheel.
If your older Whirlpool clothes dryer model has a kickplate, remove it first. You can either pop it off, or pry the kickplate off the interior spring catches. Depending on your model, you may have to use a putty knife to push in on the spring catch at the center of the top of the kickplate. With the kickplate removed, proceed to lift the cabinet top.
Use a putty knife, or some other thin and flat object to wedge in under the cabinet top. Your goal is to push each of the two interior spring catches back out of the way, thereby releasing the cabinet top. The spring catches are located one on the left side under the cabinet top and one on the right side under the cabinet top.
Loosen the two bottom screws securing the front panel to the unit. Do not remove them just yet. Locate the two screws at the inside top of the cabinet. They also help to secure the front panel to the dryer unit. Remove these two screws. Balance the front panel as best you can as you remove the two bottom screws that you have just loosened. Disconnect the wire leads connected to the door switch. Hold the dryer drum in place and remove the front panel of your dryer. Some models may have extra screws holding the front panel in place. If you are having difficulty removing the front panel, do a check for more screws.
Reassembling the entire unit is basically the disassembly process in reverse. Reattach the front panel of the dryer in the same manner you took it off. Make sure you reattach the wire leads to the door switch, and replace all of the screws that were earlier removed.
http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/3406129/2702?modelNumber=WED5300VW0#repairHelpVideoTabs You will want to watch this. It will tell you how to replace the seal on the door.
http://www.repairclinic.com/PartDetail/Drum-Support-Bearing/279441/2683?modelNumber=WED5300VW0 this will show you how to replace the ring seal on the drum.
These are so detailed, I think it's all that you'll need to complete job. These whirlpool dryers are not hard to work on once you know how to do it.
I really hope this helps you. I hope that everything you need is covered here.
Thanks,
Mike
Aug 06, 2011 | Dryers
I need to replace a sensor kit on a whirlpool dryer model len2000pwo. should i go in from the back of the dryer or front/top!!! The part was in the dryer drum when i found it so im not sure the best...
Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Opening the cabinet for newer Whirlpool brand models starts at the control panel. Begin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit.
Proceed by removing the kick-plate. There are two spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kick-plate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
Dec 01, 2010 | Dryers
Drum does not turn
HI. This may be a possible belt issue. the belt may have slipped off, or failed. To access, simply, remove the access panel on the rear of the unit. Once removed, you will be able to inspect the belt location.Replace the belt, if needed.
Additionally, if the belt is ok, i would recommend to move on to the door switch. Most units are designed to not spin, if the door switch circuit has failed. Use the procedure below to test this switch.
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
Now, if the door switch is ok, and operational, the motor will be the culprit.
Dec 06, 2009 | Whirlpool LEB6300 Electric Dryer
Whirlpool Gold Ultimate Care II Electric Dryer
Hi, there sould be a two piece door catch. One piece on the door and another on the front panel that the door closes to. Look at the piece on the door. You will probably find it is bad. You can buy just that piece and change it. I hope this helps. If I can assist you further please let me know.
Thanks
Vic
May 13, 2009 | LG DLG2524 Gas Dryer
Wirlpool gold dryer gew9868kq1
Please explain what is intermittent. Thank You, Sea Breeze
Mar 16, 2009 | Whirlpool GEW9868K Electric Dryer
How to remove the back
Dryer back does not come off, the screws removed secure parts to the inside of the case.
put them back before anything detaches.
the front panel comes off
  • pull wall plug
  • remove lint screen
  • remove 2 screws in housing under lint screen
  • with putty knife or other blunt blade in gap between top and front,
    depress spring catches at both corners of top panel front, tilt up top
  • remove 1screw each side 1/3 down front panel
  • remove door swicth wires
  • tilt front panel down and remove
all internal parts are accessible
perform repair
examine rear of case from inside and refit anything detached by screw removal
reassemble in reverse order
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
I am trying to figure out how the cabinet to my dryer comes apart so I will be able to replace the heating element.
If your dryer has the lint screen on top of the cabinet, the heating circuits are located in the rear of the dryer. They can be accessed by removing the rear panel.
If your dryer has the lint screen in the door, the heating circuits are located under the dryer drum. They can be accessed by removing the lower panel under the dryer door. The panel comes off by inserting a putty knife in the seam, about 2 inches in on each side and depressing the release tabs. If this is a Kenmore Elite or Whirlpool Duet model, the lower panel comes off by removing the screws under the bottom edge of the lower panel.
If there is no removable panel, the entire front casing needs to come off. This is accomplished by lifting the dryer top to gain access to the screws that hold the front panel place. Use care not damage the door switch connector(s) in the process.
Lifting the top panel can be accomplished in the following ways (depending on model):
1. Grab the sides of the top panel and pull towards you while lifting up.
2. Lift the operator console first and then remove the three screws holding the top panel in place. Once the screws are removed the panel slides forward, then off.
I hope this is helpful to you. If you experience problems, please post back with your model number, so I can narow down which dryer configuration you have. Good Luck.
Jun 06, 2008 | Whirlpool Dryers
Can't remove motor from dryer
you need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
Nov 29, 2007 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
