Question about RCA HD50LPW42 50" Rear Projection HDTV
Vertical lines appear on screen...
Hi everyone. Can you please help diagnose a problem I am having with my TV?
My HD50LPW42 works fine when first turned on. After a certain length of time (varies)... the screen has these vertical lines that appear evenly spaced across the screen. They sometimes disappear and reappear without any strange sounds, etc. coming from the TV. All the time, the sound is great without any other problems.
When I power down the TV, the lines continue through the "blue" power off screen.
Any ideas what the problem might me? How do I fix it??
Thanks!
Mark
  • 80 Answers
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
Posted on May 21, 2009
I have 5 thin vertical white lines on the screen sound is fine.
It looks like the problem is comming from your LCD chips, they are starting to burn out and that is why you get this lines across your tv set, if you leave it like that the problem is only going to get worst
the lines will get bigger until it finally covers your whole screen you need to replace the OPTICAL BLOCK to fix this problem
good luck hopes this helps
please rate this solution !!!!!!!!!!!!!
Jul 05, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Grey vertical line appears on screen
I had the same problem with my Lnt4071f. I called tech support and they said it was a faulty panel and the entire set had to be replaced. If you have your warrantly still use it, if not you may just be able to replace the panel, but its expensive.
Dec 27, 2007 | Disteck P4204TWHD Television
RCA DLP/HDTV Vertical Lines
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Dec 19, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
RCA HD50LPW42 50" Rear Projection HDTV Logo
180 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
