And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Stop blowing cool or stop blowing anr air through the vents??? If it stops blowing cool air, check if the condenser fan is running (it should be)( on drivers side under hood, looks like a small radiator) if not take a water hose and deluge the condenser with water, if it then cools, you will need a new condenser fan assembly.
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
sounds like they cant find the problem, i dont think an 03 would have that kind of wiring problem, i think there guessing, could be a bad compressor, but hard to say without checking it . good luck, maybe its time for a 2nd shop to look at it.
