Question about Maytag PYE2300AY Electric Dryer
My dyer is making a rattling sound what is cause it to happen
Dryer making rattling sounds
    President:
  • 1,136 Answers
Hi, It sounds like the blower wheel is bad. This is a common problem.
While the dryer is running, listen to the front lower left corner and see if you can pinpoinnt the noise area.
If this is the case, please let me know if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
My dyer is makes a loud, rattling sound.
did you find what caused the blower fan to break in the first place?I suspect the casing around the fan may not be clearing and something is in the fan again. or the keepers to keep it on the motor shaft are loose. The rollers for the drum and belt may be faulty. these are all of the parts that move so it has to be one or more of them.
Mar 01, 2012 | Amana NED4500VQ Dryer
My kermoremodel417.69042991 the problem his i turn the dyer and make a very ogly sound and dont stop
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 19, 2010 | Kenmore Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
Dyer making noise
maybe there is a dust or its full of clothes!
Jul 22, 2010 | Maytag MDG2706A Gas Dryer
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Hi, Can you tell if the noise is in the lower front? It sounds like maybe the blower wheel has went bad. I can assist you further in this if you need.
Thanks
Vic
May 21, 2009 | Maytag MDG5806A Gas Dryer
Dyer no movement/heat on stack unit- washer fine
It sounds like the dryer motor please change thanks
rate me
Apr 20, 2009 | Dryers
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
