Question about Brother EM-530 Typewriter
Faulty print mechanism
Kb leds flashing
changed correction tape and now it rumbles at start and then kb leds flash.
  • 418 Answers
Re: faulty print mechanism
Make sure the correction tape is not loose and catching on the daizy wheel and the the hammer is snaped into it position
Posted on Oct 16, 2007
0 characters
3 Points
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Typewriters
Typewriter not working; What could be wrong?
You have a broken plastic print solenoid cap. I sell them with instructions for 20.00 includes shipping.
Aug 06, 2012 | IBM Wheelwriter 1000 By Lexmark Electric...
I am having problems changing the correctable ribbon. It does not correct after installation.
if it prints but doesn't correct, it is probably a problem with the correction tape. make sure the tape is instaled in the correct postion with the dull side towards the paper
Mar 14, 2011 | Brother GX-6750 Typewriter
While correction a word growled flashed the on light and died. now it wont turn on and i cant get the ribbon cartrage out what should i do
Carefully remove ribbon and tape then printwheel. Turn on before re-installing. Corr tape is probably caught up in printwheel.
Nov 18, 2010 | Smith Corona Wordsmith 100 Typewriter
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Installed new ribbon. appears correctly installed.
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
Oct 02, 2009 | Lexmark Wheelwriter 15 Series II...
Changing correction tape
i have the same problem. can't find a manual anywhere. someone please help
Mar 10, 2009 | Brother ML-100 Typewriter
Lost manual for Smith Corona sl 575 spell right typewriter
how do I replace the correcting tape in my Smith Corona Spell Write XD6600?
Jan 06, 2009 | Typewriters
KB? Pitch?
maybe your printer stuck,try to move him manually and then start typewritter
May 07, 2008 | Brother EM-530 Typewriter
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Brother EM-530 Typewriter Logo
111 people viewed this question
Top Brother Typewriters Experts
Ron Dufek
Ron Dufek
James Cagle
James Cagle
Jim Keysor
Are you a Brother Typewriter Expert? Answer questions, earn points and help others
