Question about Dryers
My Kenmore dryer is not heating. Need to check heating element.
I suspect the heating element on my Kenmore dryer is bad (model 417.84252500). I want to check it but I'm having trouble accessing it. The back of the dryer does not come off and is permanently connected to the sides. Do I have to remove the front and then remove the drum to get to the heater?
  • waybern2 May 16, 2009
    Thanks for the quick response but on this model, the heating element is in the back behind the drum.
    President:
  • 1,136 Answers
Hi, You need to remove the front lower panel. There you will find the element on the right side under the drum. If the element checks out ok, then you need to test al the thermostats and the safety fuse. With he dryer unplugged, check all these parts for continuity. If any of them show no continuity,replace it. If I can assist you further, please let me know.
Thanks
Vic
Posted on May 16, 2009
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
I have a 80 series Kenmore dryer, runs fine...no heat. Help!!!
Your heating element is burnt out or a high limit switch has gone bad. I suspect that the element is out since it is hard to blow a high limit switch. To access the element you will need to remove the back of the dryer and in the bottom left hand corner there should be a box, or tube, that contains this element. It looks like a toaster element. To see if the element is bad you will need to run a continuity test or visually inspect this coil for any breaks. If there is a break you need to take the model and serial numbers to an appliance parts house for replacement.
Good luck on repairs hope this helped you some
Dave
Jan 20, 2010 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Kenmore Dryer model 110.62932100
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Kenmore 659 Electric Dryer
We have a kenmore dryer model 11068934792 ser. mj3303110 -90 plus series we do not get any heat when it is running
It sounds like you have a bad heating element or thermal fuse. The fuse cannot be reset. If it is bad, then it will need replaced. Often a dryer heating element burns out, but doesn't triop the circuit breaker or blow a fuse. The heating element is simply a long coil of wire. You can check it for continuity with an ohm meter. No continuity means that the element is bad and you will have to replace it. The elements are not repairable. Hope this helped.
Jul 16, 2009 | Dryers
No Heat on Kenmore Gas Dryer Model 417
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
Thanks
Vic
May 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Electric Dryer will not Heat
Define checked everything. Usually when your dryer is not heating but blowing air its one of three things...
1. Thermal fuse in dryer
2. Thermistor in the dryer
3. Heating element in dryer
You need a signal meter with continuity check to accurately test all three componets. Normally the fuse and thermistor are in a set and cost less than 25 bucks. They are easy to replace if you are good with taking things apart. If the element is bad then you need to make sure your lint trap and exhaust hose are clean and kept clean. That is the main cause of the element burning up when it gets lint collected inside the dryer cavity.
In a pinch if the element is bad you can simply find where the metal has broken and try bending the rod so that it touches. The element has to be one solid piece so if there is breaks try and connect them back together until a new one can be purchased.
Please unplug the dryer before doing anything mentioned above.
Hope this helps
TankMurdock
Apr 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore HE4t Dryer - no heat
The usual suspect for a Kenmore HE that runs, but doesn't heat is a thermal cut-out or the thermal fuse. Although they are a bit more resilient, in some cases the heating element itself could be bad. The way to check: 1. UNPLUG THE DRYER, FIRST. 2. Remove the bottom kick plate on the front of the dryer. 3. Remove the blower fan cover directly under the lint screen. There should be a couple of 1/4" screws holding it on. 4. Directly behind the blower fan cover on top of the blower fan housing are two components. One is the operating thermostat, and the white one is a thermal fuse. The fuse is a one-shot fuse that must be replaced if it is bad. 5. To the right is the heating element housing. There are two additional components mounted on the side of the element housing. The component furthest to the back is the thermal fuse. The one one closest to you is the hi-limit thermostat. 6. Check the continuity of thermal fuse and the thermal cut-out. They both should read a short. Additionally, check the resistance of the the heating element. The element should read something low (less than 20 ohms). 7. If the thermal fuse reads open, replace it. If the thermal cut-out is bad, replace the hi-limit thermostat with it. They are usually sold as a set. If the heating element is bad, you will need to disconnect all electrical leads and remove one 1/4" screw holding the element housing to the bottom casing. Pull the entire element housing from the dryer. Depending on model, sometimes the element slide out of the housing, sometimes you will need to remove a few screws to open it up. I hope this helps you.
May 24, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
