Question about Hitachi 53SDX01B 53" Rear Projection Television
No sound on hitachi 53sdx01b
No sound. Everything else is fine. Is there a fuse that can be replaced?
I had no sound either and everything else was fine so as suggestd I unplugged tv and waited 10 seconds like suggested and it worked, thanks!
Posted on Mar 30, 2008
I just unplug the power of the tv and waited for about 10 minutes. This worked just fine and I had sound again.
Posted on Jan 29, 2008
    Genius:
  • 1,694 Answers
First, there is no fuse to replace.
Next,have you tried more than one source such as playing DVD?
Have you gone thru all audio menu selections?
Please give max feedback so we can help........T.
Posted on Nov 05, 2007
Took back cover off, followed speaker wires to board, unplugged and re-attached, speakers now work.
Posted on Oct 16, 2007
  • 4,889 Answers
The first thing to try is rescanning the Freeview channels as it may just be a software corruption...if you have the option of "1st time installation" pick that.Also let me know if there is any buzzing sound coming from the tv..
Need a lower rear board Part #H512264
No one has it in stock--board should be repairable unless lost etc.
http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/53SDX01B.aspx
You might also contact PTS Electronics who repairs boards and may have one of these rebuilt as well.
If its the board with the RCA jacks it may be fixable.
May 02, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SDX01B sound
This set had lots of audio problems- some idiot decided to put the entire audio circuit on a single compact board---it develops all kinds of bad solder connections on the numerous flat Pak chips on both top and bottom of the board.
Board no longer available from Hitachi (srs board) and rebuild usually is over 150 plus shipping.
We send the board out for that as I have seen top notch experts spend hours trying to solder the board and not after have a working set.
Hitachi just crammed too many parts in too small an area and the heat bakes the board---Understand I was seeing this failure when these sets first came out--failing after a week or two in someones home.
Apr 13, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I need a mirror for a hitachi 53sdx01b
Hitachi USA or Andrews Electronics in California who ships all over and is the largest OEM parts dealer in the USA.
You can also Google the brand/model number with replace mirror after it as there are some vendors on the internet who sell replacement mirrors.
let me know if you have questions as I am here to help you.
Mar 13, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My tv has no picture or sound, but the power is on...
Replace your STK ICs -STK392-110s use 120s
Mats has ICs 1-800-628-1118
Sep 29, 2010 | Hitachi 53SDX01B 53" Rear Projection...
BIG SCREEN TV
2.5 ohm resister at 2 watts at R43 is bad on the 53sdx01b same boards as my tv , when mine went it was at 12 ohm instead of 2.5
Jul 02, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SDX01B Rear Projection Television - No Picture
i have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
Apr 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Sound, but no picture on some imputs
theres a digital switch IC on or near the AV panel that needs to be replaced if I`m understanding your question correctly you go into menu and switch to Ant. B & there is sound but no picture correct? If this is correct the IC will have to be replaced or it`s supply voltage is missing.
Nov 27, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Mitsubishi won't go on
after failure press the MENU and INPUT(or DEVICE whichever you have) and count the blink sequence there will be a first set ans second set of blinks. this will be an error code.
Nov 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SDX01B 53" Rear Projection Television Logo
189 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
