Question about Panasonic PV-V4022 VHS VCR
Can't use VCR
Panasonic PV-V4021 VCR, Try to turn on, get TU or T7 on display. Unplugged, new batteries in remote, nothing works. Can you help me? Thanks.
    Problem Solver:
  • 8 Answers
There's nothing wrong with your VCR. Your remote probably set to control your TV. To fix that, simply press the VCR button on the remote, and you should be fine. The "T-U" really means "TV," but the designers at Panasonic wanted to use the standard seven-segment display to cut costs, hence "T-U" instead of "TV."
Posted on Aug 02, 2009
I need a manual for Panasonic vcr PV-V4521
Panasonic has the manual available on the product site for the PV-V4521: http://shop.panasonic.com/support-only/PV-V4521.html . Scroll down and look at the left hand side of the page (below Support and FAQs). The direct link to the manual is: http://service.us.panasonic.com/OPERMANPDF/PVV4021.PDF . (The manual covers both the PV-V4021 and PV-V4521.)
I hope this helps.
Feb 01, 2015 | Panasonic Televison & Video
Universal Remote for Panasonic VCR PV-v4021
RCA universal Remote also I have found one that's called Onn. Works mine just fine
Sep 24, 2013 | Panasonic PV-V4021 S-VHS VCR
We just purchased a Panasonic VCR/TV Universal remote for our PV-V4021 VCR and find we no longer have a user guide. How can we set the VCR to record at a later time, such as later in the evening? Where...
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
Aug 21, 2010 | Panasonic PV-V4021 S-VHS VCR
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic omnivision PV-V4021
Read the book. ........... Get one.
Apr 17, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Apr 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic vcr
what is the model of the vcr ?
Mar 23, 2008 | Panasonic PV-4601 VHS VCR
Fisher vhs
Sorry, you need the remote. There are sites that sell remotes.
Try partstore.com
Dec 30, 2007 | Panasonic PV-V4021 S-VHS VCR
Panasonic TV/VCR Remote Problem
Hold down the play/repeat button on the TV itself for 5 seconds. That toggles in and out of demo mode. ;)
Nov 17, 2007 | Panasonic PV-M2048 20 in. Combo
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
See all Panasonic PV-V4022 VHS VCR Questions
Panasonic PV-V4022 VHS VCR Logo
246 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
