Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Replaced battery for lawn tractor and nothing happens.
I have an older lawn tractor and bought a new battery. I didn't realize I needed a reverse terminal battery and ended up matching positive with negative. There were sparks when connecting the battery terminals. Nothing happened when trying to start. I took battery back to store and they tested it-it still is good. I bought the reverse terminal battery and still nothing happens when trying to start it. It's dead. Did matching positive with negative cause this even though the battery is still good, do I have a problem with the starter?
  • bsgarrett4 May 16, 2009
    I'll try that! Thanks for your help!
    President:
  • 2,559 Answers
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
Posted on May 16, 2009
  • 585 Answers
The charging system has diodes. In blowing the fuse, you may also have shorted the diodes. If you replace the fuse and it blows immediately, the diodes are history. Disconnecting the shorted diodes will allow you to run the tractor with a charged battery, but it will not charge the battery until the diodes are replaced. The correct diodes may be found through Sears, Rural King, TSC, and others.
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman lawn tractor
charging system need to be check... alt. some of these tractors have the charging reg. inside alt some have one mounted outside follow wire the red one should be one big (thick) one and a thinner (smaller one) this small one is the charging circuit. if it goes from battery to alt. then regular is inside alt.
Oct 04, 2017 | Craftsman Garden
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My lawn tractor died and now is readind dead but the battery is new
Sounds like your charging system is burnt out or your battery cables wheren't tight enough when you reinstalled your new battery and as soon as you started it the first time and you ran the battery down it didn't charge, take the cables back off and clean them greese them up and put them back on and tight them up and charge the battery up and you should be good to go
Jul 27, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
19.5 hp twin craftsman serial number 917259560 turn key nothing happens battery new, switch uner seat in ok position
Check that the blades are not engaged. If they are not engaged and you still have nothing, check battery cables tight. Then check the starting solinoid.
If you have any questions on how to do this or other related, just reply.
Jul 13, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
535 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
