Question about InFocus Proxima DP6155 Multimedia Projector
Hot to adjust the convergence on the DP6155
After running for about 10-15 min the convergence goes out of alignment. How can I adjust it or what is the solution. Any help would be greatly appreciated
  • hubbub May 14, 2008
    mine is real similar, my bulb is weak, but i have the red way to the left, double image, need some info.plz.
  • kliushkin Nov 02, 2008
    I have the same problem on my ASK C100 projector. A blue color get a big shift to the left side. The misalignment increasing with a running time.
  • 2,237 Answers
Resolder the fingers on the edge of the power supply where it goes into the main board edge connector.
Posted on Dec 29, 2009
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Tried to auto adjust the guns, will not come within range
Hi Tod,
If colors do not align correctly, most likely you have a convergence failure. This requires replacement of the 2 STK ICs and possibly some low ohm resistors.
Some Toshiba have a Horizontal oscillator/Drive IC failure that results in a small or shrunk picture (2-3" border on all sides). The 3 colors do not align properly because of the reduced Hor drive signal. The convergence adjust controls will work but not allow good adjustment. Convergence is ok, Hor Drive signal is incorrect.
Many do-it-yourselfers mistake the Hor Drive problem in Toshiba RPTV with convergence failure. Too much adjustment of the convergence controls may cause the saved data to be really messed up and require more difficult alignment in the service mode.
If minor or simple adjustments in the customer convergence adjust menu do not fix your problem, there is a fault. Stop adjusting until fault is repaired
Convergence failure can be accurately identified with the Convergence Gallery on our website. Service in Toronto, Ottawa, Calgary, Edmonton and other Canada cities.
easyab
Apr 21, 2010 | Toshiba 42H81 42" Rear Projection...
All colors are out of alignment. It is fine but after watching it for about 20 min. It will fall out of alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2009 | Mitsubishi VS-60805 60" Rear Projection...
GE 60in Big Screen(Convergence won't Align)
do you know how to solder? If you do you can redolder the two convergence IC's on the convergence board and it will probably cure your problem. These IC's usually are against a large metal heat sink they stand up and have quite a few pins on them. If you try this you need a pencil solder iron and solder and do not solder any of the pins together.
Aug 10, 2009 | Toshiba TP55H60 55" Rear Projection...
Hitachi 50FX20B 50 inch: Blue Convergence --will not adjust
You need to change convergence amplifiers. Should be no problem for a professional
Apr 08, 2009 | Hitachi 50FX20B 50" Rear Projection...
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
Red arching lines
is this that you are adjusting called convergence? If so then if it's really bad you can try to reset convergence, if not then the red needs to be aligned up with green first then blue on green. Can you provide a picture of what it looks like?
Apr 13, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Nov 14, 2007 | InFocus Proxima DP6155 Multimedia...
RCA P46159 Convergence
Why would the set go out of adjustments? I highly doubt if the set needs only alignment. These adjustments are for small drifts only. If anything is way out more then what the on screen can adjust, you have a problem with the convergence correction circuit. There is a convergence power supply in this set that goes bad a lot in these TV sets. There is also a convergence driver board. These RCA sets do not have the integrated IC's like most sets do. Each convergence yoke, horizontal as well as the vertical, has two independent power amp circuits driving them. And that's for all there tubes. So there are 6 separate amps controlling the convergence in these TV sets. You really should call in an RCA authorized repair shop to assist you in this repair. Good Luck
Oct 01, 2007 | Televison & Video
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
InFocus Proxima DP6155 Multimedia Projector Logo
666 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
