Question about GE Profile JTP18 Electric Single Oven
LED says "Locked" can't turn on stove. How do you unlock it?
We can't seem to turn on our stove. It now shows "locked" when we try to turn it on.
  • 10,865 Answers
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
Model# AC53350AF Stove locked up at cleaning cycle
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Dec 26, 2010 | Amana Ovens
Whirlpool self clean GGP84803 door won't lock when initialized.It is clicking and diplays locked but I can still open door?
If the lock will not engage and keeps locking and unlocking then turn the power off, slide the stove out to obtain access to its back. Remove the 3 screws from back cover and you will see the locking motor and a switch with a lever that rests on the locking rod. This lever has lost its firmness and does not engage the switch to tell the motor it is locked. Simply take a pair of pliers and bend the lever down to put more load on the lever. Now when the rod turns it will fully engage the switch which will tell the motor that the door is locked. Test your setting to make sure you have it adjusted right and then re-install your cover and push your stove back into position and enjoy your day. Takes 10 to 15 minutes and is cheaper than calling a service tech. Remember to turn the power off when working on the back of the stove through testing and such. No need to get hurt.
Jul 02, 2010 | Whirlpool Ovens
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile JTP18 Electric Single Oven Logo
673 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
