Question about HP Compaq d530 CMT Intel Desktop PC - Intel Pentium 4 2.8GHz, 512MB DDR, 40GB HDD, DVD-ROM/CD-RW, Gi
Screen says mode not supported h:53.4khz v;84.ghz
When I Connect my HP to my monitor I get this message; mode not supported H:53.4khz V:84.ghz What should I do.
  • wellofwaters May 16, 2009
    THANK YOU THANK U THK U This is a hlepful site.
  • 221 Answers
You should reboot your computer. Immediately after you see the BIOS splash screen (Dell, Acer, HP, etc...) start pressing the F8 key 2 times every second. If you're quick enough, you'll get the Windows boot menu. When you see the menu, select "VGA Mode". This will boot Windows with minimal video settings which are compatible with all modern monitors.
Once Windows loads, right click on the desktop, select Properties, go to the Settings tab, and begin sliding the resolution bar up from 800x600 and clicking Apply. After each change, it'll ask you if you want to keep the settings. If you can still see the screen, click Yes. If you get to a setting where your monitor goes black and says "mode not supported", then wait 15 seconds and it'll revert to the last mode that worked. Leave it there.
Here are some typical resolutions for monitors:
17" = 1280x1024
19" = 1280x1024
19" widescreen = 1440x900
21" = 1600x1200
24" = 1920x1200
Hope this helps!
Posted on May 16, 2009
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
Tip
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
SOLUTION (FROM HP):
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
on May 21, 2010 | Computers & Internet
The computer starts and the monitor instantly goes into sleep mode and cannot be restored. It first shows that there is no inputs and goes into sleep mode
It is possible that your video card is Gone!!! Try to connect the monitor to another computer (to a laptop for example) to verify if it works properly.
Jan 01, 2012 | HEWLETT-PACKARD Hp Pavilion Elite Hpe477c...
Does this card support dual screen mode? I just bought a monitor that I'd like to use with my HP Pavilion dv6t. I can't set the resolution higher than 1366 x 768. I am told that if the video card must...
Dual screen mode? You mean dual monitor mode?
But anyways, the maximum resolution that you can obtain on your Pavilion dv6t is 1366x768 unless you attach an external monitor. Even then, only the external monitor can go above 1366x768 resolution. You're laptop screen will remain at 1366x768 max.
Ericthecmh
Jul 31, 2010 | HP Pavilion dv6t Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Message is input not supported Screen is black with message scrolling, monitor will not communicate with server
Might be the VGA cable of Monitor is not connected with CPU or vice versa.Pls check it and re-connect.If still problem is coming then start the system and press F8 continuously still dos screen and choose a option that Enable VGA Mode.after that login through and re-configure the monitor compatible setting by right click on desktop and click on setting select 1024.768 and apply.
Nov 16, 2009 | Computers & Internet
How do you get the covers off? "Does not support this mode"
Well here I am again trying to get the covers off of an unfamilar device. I found the 2 screws at the bottom and removed them.. On a hp 1702 I just forced the sides open, pulling and bending to pop the cover off.. How do you get this mag cover off?
Problem indicates on screen "Does not support this mode" on power up, then screen goes blank. OSD doesnt work... blank screen... Does not support message looks good though for an instant...
Feb 16, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
HP Compaq d530 CMT Intel Desktop PC - Intel Pentium 4 2.8GHz, 512MB DDR, 40GB HDD, DVD-ROM/CD-RW, Gi  Logo
233 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
