Question about NEC MultiSync LCD2000 Monitor
Nec multisync 2080 monitor
The monitor turns on for about 2 seconds then goes blank. The power light stays on which leads me to believe the power supply might be bad. If this is true can have the part number and price and where to get it.
Email kevin.pugh@medstar.net
    Problem Solver:
  • 8 Answers
I got a similar problem with my NEC 2080UXi. The power led indicator is lit as soon as I plug in power. No back light ever comes on. Capacitors appear to be fine. I did notice that a resistor did burn up and appears to be a small wattage from size of the leads. Does anyone know what resistance R915 is? It's located under the middle heat sink on the power supply board (the brown coloured board).
This may be the solution.
Posted on Apr 08, 2010
  • Oliver Hamilton Dec 22, 2010
    THE VALUE OF R915 IS 5.6 OHM . OTHER COMPONENTS MAY BE BLOWN :I/C 901, Q901,R911,R917, ZD910
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Posted on Oct 15, 2009
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
NEC MultiSync LCD2000 Monitor Logo
667 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
