Question about JVC AM FM CD DET FACE CAR STEREO
Where does the blue/white remote wire hook to.
This wire is for the remote control for the CD player in a 1989 gmc truck.
  • 221 Answers
Hi, I'm not sure I understand your question. It sounds to me like you haev a 1989 GMC truck, and you've installed a JVC CD player in it. The CD player has a blue and white wire coming out of the back, and you would like to know where it goes and what it does. Is that right? If so, then the blue/white wire labeled "Remote" coming out of your CD player is intended to turn on an external amplifier or some other "remote device". If your truck has a power antenna installed, this would be the wire that tells your power antenna to extend and retract. Many stereos have two of these wires - one for the power antenna and one for an amplifier. If you don't have an amplifier or power antenna, you don't need to do anything with this wire, just leave it alone and make sure it doesn't touch any bare metal behind the radio. Hope this helps.
Posted on May 16, 2009
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
Both wires to brake light switch are hot until brakes are pressed then one looses power. 1989 gmc truck need to wire powerstop trailor brake module. any suggestions
you'll have to find the wire that is hot when the brake pedal is pressed. hook the red wire from the module to this, the black wire will go to battery hot, the white will go to ground and the blue wire will go to the trailer connector for the rear electric brakes.
Mar 17, 2011 | 1989 GMC C1500
I have no sound with the ipod or dvd but the fm stero works. I took this out of my old truck and it all worked in there but once i installed it in my new car there is no sound when playing dvd/cd or when...
it sounds like you are going through an external amp. try using the blue/white wire instead of the blue wire. the blue wire is antenna remote turn on. the blue/white is amplifier remote turn on. the blue wire turns off when leaving tuner mode.
Feb 02, 2011 | Kenwood KVT-514 Car DVD Player
Which wire is the remote wire i'm trying to hook up an amp
The remote wire is blue, or blue white. If it has both, use the blue white.
Aug 17, 2009 | Aiwa CDC-Z127 CD Player
Where doi hook up the system remote control wire
on your wiring harness behind the stereo, you should have 2 blue wires. one solid, and a second blue wire with a white line on it. the one with the white line is your remote turn on. the other one is for a power antenna, and wont work to keep your amp on.
Aug 04, 2009 | Pioneer DEH-P7900BT CD Player
Remote wire color?
the remote wire will be a solid blue this is always the color no matter what deck you have
Apr 19, 2009 | Alpine CDA-7892 CD Player
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
Volume
make sure you burn your music on a cd-r or cd-rw disk,make sur the music on the disk is not copy-righted
Jan 27, 2008 | Jensen VM9510 Car DVD Player
JVC AM FM CD DET FACE CAR STEREO Logo
958 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
