Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door doesn't close properly
The garage door starts to close but then backs off as if the sensor is tripped. This consistently happens every time the door closes at a certain point (approximately 1 foot from the bottom and no there is nothing protruding from the door that is tripping the sensor). This inconsistently happens at various other points along the path.
the sensors are clean. I cannot tell if they are pointed directly at one another, but they are very firmly in place. This problem just started happening recently. Opener is about 9 years old now. My Sears Craftsman door stops right above the sensors and reverses back up every time I try to close it. It will not go all the way down even when the button is held down to by-pass the sensors. We've tried adjustng the pressure and the travel distance. The door slides smoothly on the track when opened and closed manually. Before this started it was going down all the way and then reversing. We could stop it in place by pushing the remote button again. Any other ideas for us to try?
  • 31 Answers
I too am having the same issue. I replaced my console control because my garage door was unresponsive and that fixed that issue. Now I have to hold the button down sometimes double tapping the button and then holding it down to close it. I believe the first place to check is the limit switch. Look at your owners manual or get online help in adjusting that. If that does not work you may need a new logic board. As far as the sensors go, one is a sender and one is a receiver. They have indicator lights and when they are aligned they light up. Check those first as a logic board is usually alot more expensive. Check ebay though as I did as there are plenty of good used parts available. Just get the numbers off of your logic board so you know what to look for as far as model number and date of manufacture. Good Luck.
Posted on May 16, 2009
3/4 hp Craftsman garage door going back up when closing.what shiuld i do?
If it completely closes and then goes back up and the lights are NOT flashing adjust the down limits (its going down to far). If the lights flash repeatedly then something is tripping the safety sensors. Finally if its going almost all the way down and then comes back up adjust your down force.
Oct 30, 2016 | Building Materials
Seceuroglide garage door
No doubt you have a rambling controller that changes the codes quite often. That protection prevents other from opening the door when you are away. It sounds like your hand controller needs a new battery, or a neighbor used their device that just happened to trip your sensor. Call the manufacturer and get assistance, have them run you through the process of readjustment.
Feb 26, 2014 | Building Materials
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
My garage door opener from sears will not close the door from the outside. i have to go back in the house, close it with the button on the wall, then go back out. It does, however open the door when I...
If when you try to close the door with the remote it starts down and then the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Each of the sensors has a small light that should be lit and not flickering. Tweak the sensors a bit. If you cannot get both lights to come on you have bad sensors.
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
One of the trip sensors shows a yellow LED, the other sensor shows a green LED. The door will not go down unless the close button is held. A force down adjustment does not help. Even when disconnected from...
If when the door reverses the main light flashes 10 times it is a sensor problem. If not it could be the RPM sensor board which is a small printed circuit board just in front of the motor.
Jul 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener trips the GFCI
When garage doors get sticky, bent, and the chain needs lube they will trip the controls. A door may suddenly reverse for no apparent reason, that is friction. A GFCI is real sensitive to load. Also check the wiring to the unit. Any bad connection will upset the GFCI. Check all the way back to the breaker box, sometimes the screws on the wires need to be tightened.
Apr 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
I just had this problem and I cleaned the sensors and made sure all the lights on the sensors were on. They were but yet the propblem persisted.
I checked all the wires and found that the wires were touching where they went into the unit. I separated them and all is working fine now.
Dec 27, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
293 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
