Question about Roper RTW4100SQ Top Load Washer
Water runs contiuously... tub never fills...cycle doesn't start.
When i start the wash cycle, the water continuously runs. the tub never fills and cycle never starts.
    President:
  • 1,136 Answers
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
Posted on May 16, 2009
  • Victor
    Victor May 16, 2009
    Even if part of the hose is above the water level, the end of the hose has to be in a drain pipe. If the end of the hse is in a pipe but is taped or fastened to the pipe so that it is air tight. The water has to empty from the hose to the point that air can draw back into the drain hose. This help?
  • Roper Master
  • 8,220 Answers
Drain hose too low(must be 30 inches above the floor) OR the water level switch is not detecting the pressure. Remove the hose and blow out the trash and sand in the bootom of the tub and pump out the water. Retry.water runs contiuously... tub never fills...cycle  - ab20a68.jpg
My kenmore 400 washing machine isn't filling with
Check to be sure the drain line is higher than the tub.
Nov 20, 2012 | Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Water continues to fill the tub. Will not shut
Hello.......It is possible that the little tube running from the pressure switch to the tub is holed.......if so the water will continue to fill and the appliance will not start...Follow the tube down to the tub..or expansion chamber examining it for damage .you can repair this by splicing or replacing the tube..
regards Sir Galahad
Aug 27, 2009 | Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Roper RTW4100SQ Top Load Washer Logo
225 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
