Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Poulan ride on lawn mower will not run by itself--if you pour gas into the intake it will run until the sm amt runs out
Poulan riding mower willl not run by itself--if you ppour gas into intake it will run until it burns the poured fuel off
  • 376 Answers
It could be your fuel shutoff solenoid is not working or is stuck from gum, varnish or rust in your carb bowl. The fuel shutoff solenoid is located on the bottom of your carburetor. To check it, have someone, or yourself if you can reach the ignition switch, turn the key to the on position and back off several times while you listen by the carb. You should hear a click each time. If not, the carb will have to be taken off and cleaned and checked. You will probably find water and/or rust in your bowl plugging up the main jet. Best to take it to a shop.
Posted on May 16, 2009
What causes poulan riding lawn mowers not to start has gas in starter work motor want turn
there are a series of safety micro switches in the system that prevents the motor from starting
you have to be in the seat, in neutral , blades disengaged and the brake on with most ride on mowers before that will start
Apr 25, 2016 | Poulan Garden
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Poulan riding mower starts and runs for a few minutes then "chokes out" and stops running, why? If I let it sit for about 30 minutes I can restart it and finish the lawn. Now it runs for a few minutes...
If you have already changed your fuel filter and spark plug, look at your fuel tank cap. The breathing holes may be clogged with dirt or debris preventing good fuel flow. I happened to spend $150 bucks for this $5 fix. Hope this helps.
Aug 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Jun 24, 2009 | Poulan "Poulan" Push Mower
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
345 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
